I own a CATC FireInspector IEEE1394 protocol analyser that I hope to use to inspect data flowing between a host computer and my IEEE1394a equipped thermal cameras.
The short version of my request..... Does anyone have the PC software for a CATC FireInspector IEEE1394 analyser ? Anything earlier than version 2.01 is of great interest to me. There are NO licencing issues with sharing the software as it was available as a free download and uses the analyser hardware for licencing purposes. I downloaded the last (2004 - V2.01) version from Lecroy, but cannot use it.
The long version of my request with an explanation of the issue that I am facing......The CATC Fire Inspectror is a very capable IEEE1394 analyser that became part of the Lecroy stable in 2004 and Lecroy still have the required PC software for free download in their software support archive
Sadly life is rarely so simple when dealing with specialist data analysers and I have discovered that the software version is too recent for my particular FireInspector so it is incompatible. To upgrade the firmware in the FireInspector requires a support licence that is likely no longer available anyway.
The "software maintenance licence" status is dictated by a key file loaded onto the actual analyser hardware and the new firmware is present in the downloaded free software but cannot be loaded into FireInspector hardware if the "Software Maintenance" key is not valid and still current (mine is out of date). Sooooo frustrating !
The kind message from the latest software states that I cannot update the firmware to make it compatible with the software but I can download the older software versions for free from the CATC servers...... except they are long gone
Hence my quest to find a fellow FireInspector owner who has older PC software versions that I can try with my unit. There are no licencing or software piracy issues involved as the actual FireInspector hardware is the licence and permits software version use up to its Engines firmware revision level. I am not trying to enable or circumvent the "Software Maintenance" support licence.
For interest my FireInspector Hardware contains the following firmware:
Firmware = 1.08
BusEngine = 2.01
Hardware Serial number available upon request
PC Software version 2.01 is the last release in 2004 and requires the following firmware versions.
Firmware = 1.14
BusEngine = 2.02
As part of the support contract CATC ensured that you can only upgrade the PC software if you also upgrade the firmware versions
That is effectively how they managed their software version licencing. To enable firmware updates, the hardware serial number is used by CATC to create an 'unlock key' that is sent to the hardware to authorise the update routine. Without the key, you remain at the current firmware level but can still use your current PC software. Sadly I do not have the original PC software though
Best Wishes
Fraser
