Some education please.
I've just acquired a couple of, in most respects, DDA-125s to use as 4 channel scopes.
The manual says that to select all four ADCs to support one 8 GS/s channel, select 1 or preferably Automatic, noting that I need the PP096 input adapter as well.
One unit displays options for 1, 2, 4 & automatic selection of the correct number of channels in the block on the horizontal set-up menu
The other just displays 2 & 4 in the same block on the set up menu.
Neither had the PP096 adapter fitted.
Is anything (hardware or software mod) required to be able to create a single 8 GS/s channel? Am I missing another selection?
On the one that doesn't do what I expected, combining pairs of channels works as it should.
Thanks!
