Yes dedicated Roll mode will serve your needs but the trigger selection is your most powerful tool in a DSO.
Use the Roll mode button and dedicated Roll mode works differently to auto Roll mode.
First decide what trigger type or channel will start a capture and use another channel and Single trigger mode if necessary.
To maximise the amount of memory vs timebase setting split the inputs onto each or the ADC's, eg use channels 1 & 3, 2 & 4 etc to gain the full memory available.
I might not need a separate trigger. Based on some bench experimenting, for the ultimate application I can probably start the Roll, then start the engine. In this way it should capture details of the duty cycle start up. After some time (probably less than one minute) I can manually stop the Roll and turn the engine off.
For the bench tests/learning:
Source: square wave gen circuit at ~7.5 Hz (variable), ~10 V peak
Horizontal: 5 or 10 sec/div,
Acquisition: 1.00 kSa/s and 140kpts.
Input: 10X probe and scope channel set to 10X.
Roll, save BIN and convert to CSV seem to be working as expected -- a big step forward.
Some observations that I have to search here:
In regard to "dedicated Roll", is there another form and, if so, what is the difference?
In the resulting CSV table, the Vertical settings are shown as 1/10th the actual setting; e.g., when scope was set to 2V/div, the log shows "Vertical Scale CH1: 0.20", and all the voltage data is 1/10 of what it should be. It's not a significant issue, but I'm wondering why it's not showing the actual setting and results.
The BinToCSV tool seems to have a bit of a quirk: It converts each BIN file to a csv entitiled Analog_Trace. If there's a previously converted file in the same folder, it doesn't name the next one sequentially, e.g., Analog_Trace(1) etc. Instead, when Convert is pressed, it seems to work, and indicates when the conversion is "completed", but no file appears. However, if the first CSV file is deleted, moved, or renamed before the next BIN file is converted, then it works, again using the same Analog_Trace title.
When in page 2/2 of the Acquire menu, there's an "Acq Mode" softkey with Fast or Slow options. I don't recall seeing this mentioned in the User Manual when I went through it earlier, albeit quickly, and it's not in the page 17 Table of Contents. Document keyword search capability would be useful, but I would imagine it has been discussed so we'll see what my search can provide.
