If it's the same as the WP7k scopes (also using XStream), you can do a clean install with an extra partition for the cal data to save to, install XStream, open up the service options with the pin code, and tell it to run the calibration routines. At least with those scopes, no external equipment required as the stored data is basically a lengthy self cal.
