Your comment about LeCroy designs originating with physics applications where all original data is preserved and then analyzed fits with how WaveScan is described as working however I do not think that model is necessary or even suitable for design, development, and troubleshooting.
That may be your opinion, but in reality there are many areas where having the original sample data retained so you can run various analysis modes in parallel is a big advantage. You'll find LeCroy scopes in pretty much every segment of high tech, often simply because no other scope including Keysight can offer the same performance or capabilities. And that has been the case pretty throughout their existence.
Many areas like physics?
That was where they started decades ago. It's hardly their main market.
Today this are areas like storage technologies (LeCroy scopes were and still are standard in the labs of most hard disk and other storage manufacturers), and high speed communications/networking (guess what one of the target market for the 100Ghz scope is) or aerospace/defense (for example, LeCroy is the *only* scope manufacturer that even offers procotol support for standards like SpaceWire or EFABus/STANAG3910). They have "scopes" with up to 80 channels, sampling rates of 240GSa/s and inter-channel jitter of less than 130fs. You think this is for physics when the majority of options are for communications, Vector Signal Analysis and other EE related stuff?
Apparently then LeCroy oscilloscopes are found in every segment of high tech except those I have worked in.
Well, then I guess that was either in different fields which didn't require as cutting edge in a scope. Or maybe it wasn't as high tech as you think it was.
When evaluating equipment, LeCroy has always been close to the bottom for me. These days based on historic reputation
"Historic reputation"? Which was what exactly?
which may or may not be deserved, I would group them with the likes of Rigol.
Really? Rigol which really has nohing that isn't bottom-of-the-barrel? You compare the company that makes the fastest, most advanced scopes you can find, and which supports their scope longer than any other manufacturer with a CHinese B-brand that required Agilent to teach them so that they come up with the bug-ridden products they offer today?
If that isn't a stupid statement then I don't know what is.
Pointing out other manufacturer's flaws does not make them better; just because I am not a fan of current Tektronix designs
And still that's the vendor you seem to go to for new scopes, which i guess is because you trust them based on the great analog scopes they had.
It's no secret that Tektronix scopes are crap. That's why pretty much no-one who knows a bit about the T&M market buys them unless they have no choice.
does not lead me to default to LeCroy.
So what, I never expected it did, nor do I care. Why should I, it's your business what you buy and what not, not mine. I obviously don't even know what you work on so I couldn't even recommend something even if you asked (although my gut feeling is that whatever it is it should be as close to an analog scope as possible).
Juts to be clear, I don't want to "convert" anyone, and as stated nor do I suggest that if you have a decent scope already to dump that and buy a LeCroy. All I do is show some alternative about scopes not too many people here know much about, so people know there are alternatives to the trotten path of pretty much only Keysight. You're completely free to ignore that of course and consider only those manufacturers that you trust personally, even if it's what today is pretty much the bottom scrape of all the big brands.
If that architecture wouldn't work for their customers then I'm sure LeCroy would have already given up on it because implementing a design as on other scopes where sampling modes can be destructive would make it a lot easier for them.
I do not believe this at all. LeCroy has specialized in a specific DSO design to the exclusion of markets where their reputation is poor anyway.
Which are? You already stated something about "poor reputation" so it would be helpful if you could provide some details.
It's clearly not digital storage, communications and aerospace/defense, so what are these markets where they have a poor reputation?
It is easier for them to accept the status quo than to pursue those markets.
Again, what are these markets?
I am sure they also had patent conflicts with other manufacturers which made certain designs more attractive than others and marketing is going to push what you have.
What "patent conflicts" are these? Can you provide some links please?
