I tried to search before opening this new topic but I couldn't find anything about this model:
My intention is to dismantle the object, discuss its strengths and weaknesses (especially the defects), show photos of the interior and propose some improvements to the defects where possible; and also talk about some functions but without becoming an exhaustive test from this point of view.
First of all, I propose (attaching 2 PDF files) an electronic version in English and Italian of the user manual, obtained by digitizing the one attached to the product
to disassemble the Lii-600 at the back you must remove the 4 rubber feet and under each of them there is a small self-tapping screw; furthermore in the central part there are three other screws
In the following photo I have circled the screw positions in red.
The screws are tiny and the seats are plastic so be careful otherwise opening them several times will damage them. Use the well-known tricks. Those who know them, forgive me if I mention them for beginners.
Rub the screws with a thin layer of silicone oil and before tightening, rotate the screw anti-clockwise: when you hear a slight click it means that you are aligned with the thread and you can screw it on without risk of ruining it.
Let's continue; Once the back part is removed, what you see will appear
It's the main board. Circled in red you see the back of the "rail" where the batteries to be recharged are inserted, you have to free the spring at the top from the sliding part. Here I have already done it and, saving the last track to show you, I removed the other sliding parts. At that point you can lift the card but with caution because it is connected to the display with a flat cable. By unhooking the flat cable the card will come off and you will have the Liitokale divided into the following three parts
as you can see there are three pieces starting from the left: the back part, the front part where you can see the display board and the main board. At the top left you can see one of the two semiconductor heatsinks with the TO220 case disassembled. Immediately afterwards I'll tell you why.
As I told you, the photo is missing:
- the flat cable
- the moving parts of the tracks that serve to hold the back of the batteries
The first flaw of this apparatus immediately appears quite evident. Compared to the previous ones and the competition, this device has increased the choice of charging and discharging currents and their maximum values; reaching 3 A when charging and 750 mA when discharging. For this purpose, the power supply supplied together (if you buy the one with the power supply) is 5 A.
Unfortunately, as you can see, there is very little for heat dissipation. Even of the 4 MOSFETs that each drive a charge/discharge channel, two are equipped with heat sinks, even if very small, and two are without anything, which is almost incredible in a device that gets so much publicity.
There are videos on the internet that show how these components undergo substantial overheating with the highest charging and discharging values. Furthermore, as is obvious, tracks 1 and 4 will cause minor overheating while it is strongly discouraged to use the higher charge and discharge currents on tracks 2 and 3 because without anything you risk. In one video a reviewer shows the solder terminals of this mosfet darkened the color of the board in their immediate vicinity.
It is clear that the main problem is the space before the cost of the heatsinks and the designer's desire not to use active cooling with fans.
However, dissipation is certainly the biggest problem of this device used at higher currents and there are many difficulties in remedying it due to missing space as already written.
I found a way to upgrade the heat sinks that are already there, like the one already disassembled, but I'm still trying to figure out how to do it for the ones below.
in the following photo you can see that I created a larger "custom" radiator like a puzzle with a lot of effort. I left the original on the left so you can see the difference. In this other photo
I placed the two heat sinks: the original and my adaptation, next to each other to better understand. The size of my heatsink takes up practically all the space available when reassembling the device. In the puzzle I made, all the parts are tightened well with screws and some conductive paste helps the thermal conductivity between the various pieces.
Let's go back to the photo of the whole board and look at the Mosfets on the lower part.
They cannot be put upright because they would hit the "opposite" board: the display one. I only managed to add two mini heat sinks held with a clamp; but it is a completely insufficient solution. On this point the contribution of some "willing" people would be appreciated by all; However, I will continue to think about it and if I find some barely acceptable solution I will propose it to you.
I'll end this first post here, leaving you to further discussions
Thank you
