Author Topic: Like oscilloscopes, can other pieces of bench test equipment create ground loops  (Read 748 times)
Offline ballsystemlordTopic starter
  • Student
Like oscilloscopes, can other pieces of bench test equipment create ground loops?
Like bench-top DMMs, LCR meters, DC power supplies, and load banks?
Thanks!
Bench DMM's, no.
Otherwise pretty much any instrument with a grounded BNC connector one must be wary how they use it.
Some DC supply's need be watched too as outputs are not always isolated.
The following users thanked this post: pdenisowski
Offline David Hess
  • DavidH
Power supplies usually have floating outputs, but not always.
Most other instruments with BNC connectors will create ground loops, but there are some exceptions.  For instance some function generators have a galvanically isolated output.
The following users thanked this post: ballsystemlord
Offline jonpaul
    • IEEE Spectrum
Wrong assumptions, so  title makes little sense.
Check your def of "ground loops"
j
An Internet Dinosaur...
Offline David Hess
  • DavidH
Below shows an example of a pulse generator which makes some attempt to minimize ground loops.  The shell of the output connector is isolated from the chassis.
