Author Topic: List your test equipment "scores" here!  (Read 555475 times)
Offline CJay
Re: List your test equipment "scores" here!
« Reply #1000 on: November 22, 2016, 01:37:47 pm »
Recently someone was selling Fluke 27/fm meters on ebay for $15 US ea with free shipping.
Originating thread might be at
http://www.antiqueradios.com/forums/viewtopic.php?f=8&t=310451&sid=dbeba29713fb8afd3b55daad910f56c8
Arghh, they've got some great gear for sale at great prices but shipping to the UK just makes it impossible
Offline macboy
« Reply #1001 on: November 22, 2016, 02:30:52 pm »
Picked up an older Analogue Scope, Tektronix 2236, for $135 in Australia (Melb) this morning.
Nice!  The first used Tek scope i bought was a 2236. I still enoy using it. The multimeter functions are not much use in the age of cheap DMMs but the counter and scope measurement functions I still find useful.
No cheap DMM will measure 2 Gohm, I can assure you of that. And most won't have a low ohm range with 0.01 ohm resolution either. The 8-digit 100 MHz counter is also useful if you don't have something better on the bench.
Offline mtdoc
« Reply #1002 on: November 22, 2016, 07:30:18 pm »
Good point! I guess since I don't recall having yet had the need to measure resistance at either of those extremes, I hadn't considered that!   Cool - another justification for keeping it around! (Next time my wife asks why I need so many of those things..  ;D.)
Offline wasyoungonce
« Reply #1003 on: November 23, 2016, 12:36:08 am »
Just noticed the the CTM is registering 957Hz with the probe on 1Khz probe adj.  Don't know if it's the CTM or the probe adj...probably the latter.
edit:
Ahh ....quote from Yahoo Tek group .."The spec. for the 2236 states the "probe adjust" produces 1kHz +/- 20% @ .5V +/- 5%. My scope is producing 940 Hz @ .5V p-p."  Its normal.
« Last Edit: November 23, 2016, 12:50:14 am by wasyoungonce »
I'd forget my Head if it wasn't screwed on!
Offline tautech
« Reply #1004 on: November 23, 2016, 07:48:05 am »
edit:
Exactly why you mustn't use the internal probe cal output to make ANY internal adjustment of a scope.
But some scopes have an internal frequency adjustment for the probe cal output and when they do it's handy to set it close to the spec'ed 1KHz even if it's only for sanity checks.  ;)
Avid Rabid Hobbyist
The following users thanked this post: wasyoungonce
« Reply #1005 on: November 23, 2016, 08:04:58 am »
Many thanks I'll look this up I know the CTM has an adjustable TXCO...but I'd need a ref std before fiddling with that.
Offline tautech
« Reply #1006 on: November 23, 2016, 08:20:46 am »
Don't get too fussy, you'll turn into a standards nut.  :scared:
In fact if you take macboy's advice the internal frequency counter will be plenty accurate enough.
Avid Rabid Hobbyist
Offline nctnico
« Reply #1007 on: December 02, 2016, 07:02:24 pm »
A quick update on the N3305A DC load module (150V / 60A / 500W) I bought recently. This is the photo from the actual Ebay listing:
Unfortunately the module I received was banged up pretty bad. It was well packed and the box didn't show any damage so my guess is the seller must have used an image from somewhere else for the Ebay listing. After taking the rear shield off (including the binding posts) and straightening it I tested the module. It seemed the constant current mode worked just fine but it didn't read any voltage (remote/local sensing didn't make a difference).
A quick inspection showed several resistors placed in a string hinting towards some kind of voltage divider and they where near the 'impact zone' so I measured them. It appeared some where off so for good measure I replaced all the 100k Ohm ones (4 in total). Fortunately the schematics for these modules are available and it shows these resistors are 0.1% types.
I didn't take the module apart except for removing the two capacitors on the right to allow measuring the other resistors. After the repair the voltage readout worked again and it is spot on compared to my Agilent 4.5 digit DMM. I did some further testing (full load  >:D) and it seems the module is hard limited to 560W.
« Last Edit: December 02, 2016, 07:04:31 pm by nctnico »
Offline Falkra
« Reply #1008 on: December 03, 2016, 04:18:39 pm »
Well done, good repair. :D
Thanks for posting pictures.
Offline N2IXK
« Reply #1009 on: December 03, 2016, 11:57:22 pm »
Got an oldie-but-goodie at a local ham club auction. An HP 410B VTVM for the opening bid of $1!
Needed all new probe cables and a line cord (rubber was dry-rotted and crumbling), but the thing cleaned up beautifully, and the calibration was still pretty close after all these years.
Replaced the electrolytic cap and a selenium rectifier just on general principles, and the thing calibrated in perfectly, with all the original HP-branded tubes still in it!
Really didn't NEED it, but does have an Rx1M range that reads up to 500 megohms, a DC input impedance of 100+ megs, and an AC voltage probe that works up to 700 MHz, exceeding the capabilities of my more modern gear.  Plus the AC probe (with internal tube) keeps your hands warm in the winter... 8)
« Last Edit: December 04, 2016, 12:00:16 am by N2IXK »
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline PointyOintment
  • ↑ I scanned my face
« Reply #1010 on: December 06, 2016, 03:04:43 am »
Power Designs TW5005.
$10 CAD at the local government surplus depot.
A friend of mine got one of these there two or three months ago and was quite pleased with it. I think his might have been the TW5005T version. I was envious from the moment I saw it. I don't think he knew the brand, though; I recognized it right away because it's popular on here.
This past Friday, I happened to look at the surplus seller's online list of things for sale (which is just a very brief description and occasionally a photo or two, no prices) and saw "precision millivolt source" and "twin power supply", so I decided to go over and have a look. I never found the millivolt source, which is what I mainly went for—it was probably bought between when I read the list and when I got there; it's no longer on the list today—but I did discover that the "dual power supply" was a way nicer one than I'd expected from that description. Strangely, they put power supplies from local brands nobody's heard of in the online auction section, where they fetch prices around $75–150, but Power Designs power supplies in the cash&carry section for $10!
It's remote-controllable, and it has a cord winder that the person who packed it up to sell apparently didn't notice:
There was also this note, held on by ancient masking tape that fell off when I picked it up, saying "RETURN ALL":
I haven't taken it apart yet, let alone turned it on, but I did see some interesting stuff when I looked in through the vents (on the back, hidden above the resistor house in the third photo) using another score, my new endoscope, which I got for $15 CAD ($11.11 USD) on 11/11.
I refuse to use AD's LTspice or any other "free" software whose license agreement prohibits benchmarking it (which implies it's really bad) or publicly disclosing the existence of the agreement. Fortunately, I haven't agreed to that one, and those terms are public already.
Offline VK5RC
« Reply #1011 on: December 06, 2016, 10:27:58 am »
Got an Electrometer(Keithley 619) at a fair price but the TRIAX!!!!! I think I a am about to change business!
Edit Triax AKA = TRB connector, common brand Trompeter (Thanks guys)
« Last Edit: December 09, 2016, 05:54:36 am by VK5RC »
Offline rastro
« Reply #1012 on: December 06, 2016, 05:41:16 pm »
It gets even better.
The triax on the 619 are old style (2-prong) leaving you to use an old style cable (hard to find).  Alternatively you could get a 2-to-3 prong converter or upgrade the 619 bulkhead(s) to the modern 3-prong.
Did I mention there is also 2-prog triax to BNC converter - which loses some of the advantages of the triax topology but allows for a cheaper cable.
let the good times roll...
The following users thanked this post: VK5RC
Offline N2IXK
« Reply #1013 on: December 06, 2016, 07:48:43 pm »
Speaking of triaxial cable, I needed a few feet of it for the restoration of the HP 410B mentioned a couple posts up. It is used for the AC probe cable, where the outermost shield is used to carry filament power to the probe diode. My probe cable was severely deteriorated and falling apart.
Not finding a convenient source of just a short length of raw triax cable (and not wanting to hack up a $$$ cable with connectors attached), I decided to try making my own. I found that Belden RG-174 cable (type 8216) is just about the same OD as the inner conductor insulation in their RG-58 cable (type 8240). I was able to solder a length of RG-174 (shield and center conductor together) to the inner conductor of the RG-58, and using a vise to hold the opposite end of the RG-58 center conductor, I was able to use the RG-58 center conductor to pull the RG-174 INTO the shield and outer jacket of the RG-58, creating a triaxial cable. The 174 serves as the center conductor and inner shield, with the outer shield from the RG-58 left over to serve as the filament power conductor as in the original HP cable.
Probably wouldn't work for more than a few feet of cable, but this little hack saved me from trying to track down a short length of triax, or buy a full spool of the stuff for way too much money.
« Last Edit: December 07, 2016, 05:55:57 pm by N2IXK »
The following users thanked this post: lowimpedance, VK5RC
Offline Muttley Snickers
« Reply #1014 on: December 06, 2016, 11:55:23 pm »
I've just found this handy looking device on Ebay AU and it's listed at buy now for $15.95, unfortunately it's also listed as pick up only and I'm in another state so that's out, if others think it might be of some value then I could probably contact the seller and perhaps work out a deal or somebody else here might be interested, I couldn't find any information on it via a Google search. Anyway, it's described as a Proteq Board Wizard Combi Test and I'm guessing that it might be a continuity tracer of some type, it does look pretty handy and ticks all the boxes.
Buttons: Check   :-+
Knobs: Check   :-+
LCD Display: Check   :-+
It Looks Handy: Check   :-+
It's Bloody Cheap: Check   :-+
Offline Berni
  • Country: si
« Reply #1015 on: December 07, 2016, 06:28:03 am »
I just got myself in to a worse triax nightmare. I bought a HP 4141B Source measure unit for 100 bucks and then found out it has 5 triax connectors on the back(4 SMU channels + 1 precision GND signal). Okay no biggie il just buy some cables for that, quick look online and.... they cost HOW much?! :o
I almost bought a bunch of new old stock triax connectors from a guy on ebay before i realized the connectors are 2 stud BNC while my HP boatanchor has 3 stud BNC style connectors. In the end i spent like 100 bucks again on buying 3 sets of long triax cables that i plan to cut up in the middle and put some more sensible connector on the end like XLR or something.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #1016 on: December 07, 2016, 06:41:25 am »
Don't you hate it when you get a deal on something, then wind up spending nearly as much if not more to get the manual or some needed accessory?  I suppose it's best to look at the total cost sunk into whatever it is, but even when that still works out very well it grates on me to spend the extra $$.   >:(
-Pat
Offline Berni
  • Country: si
« Reply #1017 on: December 07, 2016, 07:10:16 am »
-Pat
Well this HP 4141B seams to impossible to even buy a manual for if you wanted to. All i got online was one section of the programmers guide while for the rest a manual from a similar HP unit had to be used. No service manual what so ever to be found. This made it particularly scary when i first turned it on and the Fail LED came on, pressing the selftest button resulted in the same. Later on i found out that the high voltage interlock connector on the back needs to be shorted to GND for it to pass self test. Phew what a relief.
Another hidden cost i found is buying a >500MHz scope. Suddenly you need all new fancy pants active probes to make use of that bandwidth, and those things don't come cheep let me tell you (But then again its amazing how crisp of a signal they get, <1pF probe capacitance is a world changer).
Offline rastro
« Reply #1018 on: December 07, 2016, 04:49:09 pm »
Sometimes the last few feet going to the equipment is the expensive part.   :rant:
Offline TiN
  • xDevs.com/live - 24/7 lab feed
    • xDevs.com
« Reply #1019 on: December 07, 2016, 05:00:39 pm »
Usual ball-park pricing for low-noise triax cables with 3-lug ports is 50-200$/pc :). You can get some connectors from Digikey (TRB type they call it), about 23$/pop, as cheap as they go (if not counting ebay gambles).
Also don't confuse them with twinax which look similar and use mechanically same connector, but very different in performance and purpose.
Perhaps my article on Agilent 4142B could be useful for you, as it's similar box. If you plan teardown of 4141B, I'd love some photos! Wear non-coated gloves if you decide to peek into front end sections...
YouTube | Metrology IRC Chat room | Live-cam | Share T&M documentation? Upload! No MB limit, firmwares, photos.
Offline razberik
  • Country: cz
« Reply #1020 on: December 07, 2016, 05:51:43 pm »
Absolutely true.
Especially when you buy machine from somebody who dont know that it is. When he forgot to steal "those cables" (Probes you prick ! These "cables" are called probes !) from previous owner.
Offline Berni
  • Country: si
« Reply #1021 on: December 07, 2016, 07:53:03 pm »
I bought three 4m long triax cables for 56 USD a piece, on there way from the US right now.
That is a interesting article you got there. I actually used the manual for the 4142B to get an idea of how these things work. And i couldn't resist taking off the lid when i got it because i was curious what was inside to make the thing so massive. To give you a sense of scale the whole unit is half a meter long (about 1ft6) and takes up 4U of rack. I expected it to be half empty inside but was i wrong. Interestingly it also has 3 "shield domains" inside where parts of the internal metal case are held separated by plastic spacers. The PSU has its own shield domain, CPU its own and the large analog section has its own. Enjoy the preliminary photos(Might make a dedicated forum thread for it since there is no info on them yet quite common on ebay.).
I have not pulled out any of the cards because when i first tried to they seamed to really not want to move. Pulled so hard that i was afraid of breaking the plastic tabs. Its possible the environment it was in had some volatile solvents floating in the air since the case feels a bit sticky and some less important looking cables inside felt really sticky. Its not like it got something poured on it because any metal work around the sticky cable was perfectly clean, not even dusty. I had a guess that maybe something similar happened to the backplane connectors to get the boards so stuck in. I need to have another go at it by dissembling it a bit more so that i can get a better grip on the boards. I need to do something about that loud fan at some point, tho i have no idea where to stick a fan speed control circuit with how full the insides of it are. Also need to find some software for it or write my own.
Front ends on these are well encased in metal cans from what i can see, but i would assume its very similar to your 4142B since this unit is designed for 100V 100mA just like your medium power modules. Id love to have a high current one in here too, but then again i did get it for just 100 bucks.
Offline VK5RC
« Reply #1022 on: December 08, 2016, 10:43:27 am »
Glad to know I wasn't the only one swearing at the price of Triax, up until then I thought heliax/connectors were expensive.
I have managed to find some "2 lug" triax to triax  and 2 lug triax to croc clip cables, cost more than the Electrometer.  I think I will include them in my last will and testament!
I like the 'hack' of N2IXK with RG174 and the outer shield of RG58 :-+         Now to hack a connector somehow >:D     (not looking hopeful - but easier with the 2 Lug version)
Offline HighVoltage
« Reply #1023 on: December 08, 2016, 12:23:06 pm »
I went the same route when I got my first Keithley Electrometer and could not believe my eyes when I saw the prices for cables and connectors.
Have you looked for a TRIAX T-Connector.
Don't be surprised at $400 each and up!
Then I learned to also look for "Trompeter" connectors and found many more for reasonable prices.
Offline djnz
« Reply #1024 on: December 08, 2016, 12:38:18 pm »
USA:
Wavetek 143 20MHz function generator $68 + $18 shipping = US$86 total.
« Last Edit: December 09, 2016, 07:43:04 am by djnz »
