Author Topic: List your test equipment "scores" here!  (Read 540960 times)
edigi, alm and 3 Guests are viewing this topic.
Offline Gyro
Re: List your test equipment "scores" here!
« Reply #2275 on: January 27, 2019, 05:03:54 pm »
Ooh, it's one of their Mil spec displays  8)  I was expecting a row of their 5082-7xxx single digit ones (like the polarity indicator).
For heavens sake, don't break that, I doubt you'd ever find another!
P.S. I notice they've mounted the polarity display upside down to get closer spacing - it's normally a +/- 1 display.
« Last Edit: January 27, 2019, 05:09:01 pm by Gyro »
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline MadTux
« Reply #2276 on: January 27, 2019, 07:36:44 pm »
I brought a $19USD HP Counter that cost me $72.25USD to ship. You really don't need to worry.
I dare anyone to top paying 400% frt cost on TEA items :palm:
The Dots made me do it  ;D
That's a strange combination, perhaps the shittiest counter with the best display that HP had at the time. Usually only expensive, high end instruments had it, like HP 8340, 8350, 8662A/8663A and 8640B.
« Reply #2277 on: January 28, 2019, 01:37:09 am »
Bit strange to run a 6 digit display on a 50Meg counter too? I did also get it's better specced twin too from a different source because I have a plan  >:D
Photo below was as sent by it's former owner the day after both units were plugged together on my bench pile. The Oscillator adjustment SUX, when you go near it with a stick it flinches 20 counts making setting it good luck not correct tongue angle to set it accurately. A simple unclick to split the unit flick the internal/external reference switch and I have an accurate counter locked to the GPSDO. Insert the battery section from dotty when it arrives(with new LiPo's) and I have a portable UPS counter and GPSDO  8)
« Last Edit: January 28, 2019, 01:38:49 am by beanflying »
Coffee, Food, R/C and electronics nerd in no particular order :)
Offline Neomys Sapiens
« Reply #2278 on: January 28, 2019, 02:29:20 am »
Well, it seems quite sure now that the little AC/DC-Electronics load will not stay with me. Why?
Because I scored a Transistor Devices DLP 50-60-1000. A bit on the massive side, but it will do until a compact H&H flies my way. That is, IF it is working or repairable. It was sold as 'untested' and was mine for 127.- all inclusive.
Maybe even better is a HP6825A 4-quadrant power supply, which is supposedly working and which did just cost me 75.- incl. postage. It is my first proper 4Q-unit and as such, it might start a series.
Offline MaxFrister
« Reply #2279 on: January 28, 2019, 05:51:53 am »
The DLP50-60-1000 is a cool unit.  I repaired one a while ago.  Mine need all the pots cleaned, the fan oiled, a couple of caps, and 1 power transistor.
The entire base is a heavy aluminum heatsink with an amazing number of TO-3 power transistors.  I was impressed with how robust the design was.
Online niner_007
« Reply #2280 on: January 30, 2019, 12:04:34 am »
Fluke 720A, got it today
Offline Johnny10
« Reply #2281 on: January 30, 2019, 06:10:38 pm »
I just looked on IET website
Direct replacement for Fluke 720A     KVD-700 Precision Kelvin-Varley Voltage Divider Priced at $29,875.00
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #2282 on: February 07, 2019, 11:36:56 am »
Bought a few Tek 11801C's with matching SD-24 sampling heads. Being a sampling scope, they're only good for repetive stuff but then they are still the ducks guts. 20GHz BW *and* they double as TDR *and* you can plop in 4 modules for a total of 8 channels.
Old tech, obviously, but color display *and* touch screen. Fancy. And more responsive than more 'modern' machines.
I'm seriously considering keeping one, so the lab has a TDR handy. All the others: off to The Bay you go!
Offline Berni
  • Country: si
« Reply #2283 on: February 07, 2019, 12:03:02 pm »
Now that is a score.
I been looking for one of these for a bit, the sampling modules are easy to come by but the scope mainframe is rare. What finally turned me away from it is seeing online that the mainframes are known to be very unreliable. To top it off fixing them is difficult due to cryptic error messages and hard to find parts.
Ended up instead with a bit newer HP sampling scope with a dual 20GHz sampling module.
Offline Ice-Tea
« Reply #2284 on: February 07, 2019, 01:28:49 pm »
Well, this one seems in good shape. If the others are equally good, I'll be one happy panda. Need to test the outputs etc but looks good thus far.
Offline Berni
  • Country: si
« Reply #2285 on: February 07, 2019, 03:58:22 pm »
From what i hear the thing has a pretty extensive self test that takes a long time to run in order to test the stability of various parts. If it passes that and shows a waveform then its a good. If one of the sampling modules is busted then spare ones are easy to come by for a reasonable price.
Definitely a good idea to hold on to one of these.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #2286 on: February 07, 2019, 05:44:55 pm »
49,- including postage  :)
Offline Berni
  • Country: si
« Reply #2287 on: February 07, 2019, 05:54:13 pm »
I have heard of widescreen being a thing with scopes these days...but don't think that's the right way to do it.
But im sure a bit of poking around in the vertical deflection circuitry can sort it out. Nice price for it.
The following users thanked this post: LapTop006
Offline Ice-Tea
« Reply #2288 on: February 07, 2019, 07:09:47 pm »
Pfftt.. Have you checked the 11801C? None of that widescreen rubbish. Ultra-narrow-screen FTW!
Offline shakalnokturn
« Reply #2289 on: February 07, 2019, 07:10:41 pm »
@ Martin.M
Decent price if you were sure there was only the display problem, no bad surprises on inputs or acquisition stuff.
All the same considering sample rate and memory depth, this is the kind of scope I'd buy only to fix and play around with a few hours before reselling.
« Last Edit: February 07, 2019, 07:12:37 pm by shakalnokturn »
Offline Martin.M
  • in Tek we trust
« Reply #2290 on: February 07, 2019, 07:27:46 pm »
the repair was only 30 minutes.  :)
« Reply #2291 on: February 07, 2019, 08:10:18 pm »
That leaves you a little more play time  :-+
I followed the repair on the TEA thread, BD139 almost had it fixed before you bought it  :-DD
« Reply #2292 on: February 09, 2019, 11:45:09 am »
Yep, what bd139 doesn't know about scopes isn't worth knowing, he's the man.
Brymen-Fluke-Solartron-HP-Thurlby-Heathkit-Thander-Tek-Extech-Black Star-GW-Advance-Avo
« Reply #2293 on: February 11, 2019, 11:15:04 pm »
I got a case with 6 prehistoric Teledyne Philbrick op-amps (you understand immediately where the 'brick' comes in) and the circuit elements formerly used with them. Complete with the leaflet (i'll scan it later).
It must have been part of some educational breadboard or related.
Factually, I would have gladly spent the 30€ for the heap of Pomona double plugs with solder turrets on the side. Or for the 3  clean and 3 cleanable Pomona 2-pole cables. And that case might come handy too.
So now I can add ready-made combinations on 3/4"-spaced 4mm plugs to my kits (in addition to the 50R from Beanflying). For example a PTC like Fluke sold with the 025, or RCs, or antiparallel diodes....
The following users thanked this post: Ysjoelfir
Offline BravoV
  • +++ ATH1
HP 5347A and Tektronix 2465
« Reply #2294 on: February 13, 2019, 11:05:06 am »
A 5347A with lots of dead LCD segments, and a dead 2465.  :P
Offline ascomm
« Reply #2295 on: February 13, 2019, 11:37:00 am »
Hitachi analog 20MHz oscilloscope, 20€.
« Reply #2296 on: February 26, 2019, 02:26:05 am »
So I have splurged in the last week or so. Agilent 34461A, Fluke 335D neither of which were particular scores but are in great condition.
This is the score I had more or less given up on ever getting one of due to their normal second hand price. Sika Temperature Calibrator complete with different diameter wells. Delivered to my door will be circa $150USD  ;D
One very very broke but happy Bean.
Offline Ice-Tea
« Reply #2297 on: February 27, 2019, 01:09:52 pm »
Hmmm...  :-/O :-/O :-/O
The following users thanked this post: salvagedcircuitry
Offline SoundTech-LG
« Reply #2298 on: February 27, 2019, 05:23:40 pm »
An HPAK E3631A sold as parts only. Yes, it needed a rotary encoder...  not so bad. The display was pretty good, but I decided to replace it anyway, and keep the old one as a spare. Lots of floppy pins to deal with on that. All on the cheap. Wanted one of these for a long time, but was unwilling to pay even $300 for one.
Offline Ice-Tea
« Reply #2299 on: February 27, 2019, 06:28:24 pm »
Aaahh...  :clap:
