Author Topic: Car key fob lithium coin battery check voltage before replacing it  (Read 15076 times)
Offline zillahTopic starter
Dear Experts
Sometime I worked with my friend in his car wrecking yard , and sometime we need to check car key fobs that are not working if thier batteries are dead or not ,,,using Fluke 117 multi-meter and KYORITSU
Most batteries are Lithium Coin Battery size 2023, 2016,2025 (3V)
Some remotes fluke shows voltage for their batteries are very low obviously need to be replaced once we replace them they would work no drama
And other remote fluke and KYORITSU show voltage for their batteries almost 3V or 3.06V, 3.16V and those remote are not working but when I replace their batteries they would work !!!!
I want to know why those remotes work for new batteries while they won't work with the old batteries although voltage are still around 3v or +3V ? Isn't measuring a voltage should be a reasonable evaluation to check a battery if it good or not ? ?
Thanks
« Last Edit: May 07, 2018, 01:07:09 pm by zillah »
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Car key fob lithium coin battery check voltage before replacing it
« Reply #1 on: May 07, 2018, 11:21:39 am »
Measure the voltage, while it's transmitting.
Sometimes the batteries are depleted, but the unloaded voltage is high enough for the meter to show 3V.
Dave did a video on this.
Offline sokoloff
« Reply #2 on: May 07, 2018, 11:22:23 am »
You need to place a small load on the battery (larger than the infinitesimal load a voltmeter applies).
The battery’s float voltage could be high enough, but as soon as you draw off any current, it drops.
Cheap battery testers are readily available and easier to use (no skills and faster). I’d get your buddy one.
« Reply #3 on: May 07, 2018, 11:25:10 am »
Thanks for that tip
I am thinking how can I do that with a key fob
« Reply #4 on: May 07, 2018, 11:25:56 am »
Would a tester put a load on a battery while it is testing it ?
Thx
Offline andrewjessop
    • LinkedIn profile
« Reply #5 on: May 07, 2018, 11:29:11 am »
Thx
That is the whole purpose of battery testers... to put a load on the battery while measuring the voltage.
« Reply #6 on: May 07, 2018, 11:31:20 am »
Noted
Yes I would search for one on google
Are you aware of any decent one for lithium coin battery ?
Offline Fungus
« Reply #7 on: May 07, 2018, 11:37:52 am »
No.
Short version: Imagine your battery has a resistor on the output and that resistor gets bigger and bigger as the battery is used up. It starts as a couple of Ohms and ends up as thousands of Ohms.
Ohm's law tells us that there's a voltage drop across that resistor when current is flowing. This is what appears to cause a voltage drop on your battery but it's an illusion. The battery voltage is the same internally, you just can't see it because the resistor is in the way.
But ... there's only a voltage drop when current is flowing. If you measure with a multimeter then there's almost no current flowing and you don't see reality, you see a much higher voltage then when the battery is in use.
Bottom line: You can't measure a battery without a load on it. Put a 1k resistor on the battery when you measure it, eg 1.5k.
Offline Fungus
« Reply #8 on: May 07, 2018, 11:39:08 am »
For 3V batteries you can just use a LED, compare the LED brightness with a new battery. Simple, cheap. You can get a while bag full of 'testers' for under $1.
« Last Edit: May 07, 2018, 11:41:10 am by Fungus »
Offline MosherIV
« Reply #9 on: May 07, 2018, 11:48:55 am »
Some dmms have a low Z mode which adds a load resistor when measuring voltage.
The one I am thinking of is the Keysight U1232a
I think some other have something similar.
Offline sokoloff
« Reply #10 on: May 07, 2018, 11:54:16 am »
Any of the cheap battery testers that look roughly like this are likely to be fine.
https://images-na.ssl-images-amazon.com/images/I/41gI3OXVecL.jpg
$6 on Amazon, $2 on Aliexpress.
Offline oldway
« Reply #11 on: May 07, 2018, 11:56:18 am »
For non-rechargeable batteries, I use a fairly radical process: I measure the short-circuit current.
With a cr2032, a new battery will provide an initial current of about 50mA.
This value will fall quickly.
Use the multimeter on the 400 mA scale.
If the current is zero or less than 1mA, the battery is out of order.
Be careful, never use this with rechargeable batteries !!!!
Offline Fungus
« Reply #12 on: May 07, 2018, 12:16:20 pm »
That's basically what the LED method does, but much faster/easier than messing around with a multimeter and an LED fits in your pocket.
nb. LEDs are only suitable for 3V batteries that put out a few mA, eg. CR2032 coin cells.
« Last Edit: May 07, 2018, 01:40:14 pm by Fungus »
Offline oldway
« Reply #13 on: May 07, 2018, 01:00:18 pm »
I use this method (measuring short circuit current) with all kinds of non rechargeable batteries...but using the 10A range.
As well 1.4V, than 1.5V and 9V non rechargeable batteries....
« Reply #14 on: May 07, 2018, 08:21:09 pm »
Thanks guys for the inputs
