Author Topic: LM399 Voltage Reference, Fluke 289, Gossen 29S, RM303, AN870  (Read 8939 times)
Offline TraderTopic starter
Re: LM399 Voltage Reference, Fluke 289, Gossen 29S, RM303, AN870
« Reply #25 on: December 31, 2020, 06:45:36 am »
Just For Fun !!!
Jumps J8 and J10 are a stable 10.004 kOhms resistance.
J7 and J12 can keep a relatively stable capacitance of 156uF.
(other combinations also work with different values) (turn it off first)
« Last Edit: December 31, 2020, 07:57:19 am by Trader »
Online J-R
« Reply #26 on: January 02, 2021, 12:05:01 am »
If you want a budget reference you can rely on I would suggest the excellent VREF-01 from voltagestandard.com for only $31.  Calibrations are free for the first 2 years.
The following users thanked this post: Marco1971, Trader
Offline faraday
    • ielektro.net
« Reply #27 on: February 04, 2021, 08:01:20 am »
I tested this reference over 24h with 34410A and 33401A and so far is very stable.
                           12H                   24H
34410A              9,85795             9,85795
34401a              9,85787             9,85784
The following users thanked this post: Trader
« Reply #28 on: February 05, 2021, 06:09:46 pm »
                           12H                   24H
Awesome.  Test the Current too:
https://www.eevblog.com/forum/testgear/lm399-voltage-reference-fluke-289-gossen-29s-rm303-an870/msg3394242/#msg3394242
Offline faraday
    • ielektro.net
« Reply #29 on: February 05, 2021, 07:54:47 pm »
Voltage / time  use BNC to banana cable
« Last Edit: February 05, 2021, 08:13:54 pm by faraday »
Offline faraday
    • ielektro.net
« Reply #30 on: February 05, 2021, 07:58:21 pm »
Amp 1,82541mA
« Reply #31 on: February 05, 2021, 09:16:27 pm »
This little reference is very stable not only for Voltage but also for Current.  :-+
Offline klim
« Reply #32 on: July 20, 2024, 05:35:43 pm »
Hi, I also own these chinese LM399 references.
Could it be true, that the input voltage does effect the output voltage that much?
Input: 12,00V Ref10V: 10,22701V
Input: 20,00V Ref10V: 10,22788V
