Author Topic: Longwei PDS-3010G  (Read 14219 times)
Online Aldo22Topic starter
Longwei PDS-3010G
« on: January 09, 2024, 06:09:58 pm »
I bought something cheap again.  :palm:
A Longwei PDS-3010G 30V 10A PSU for CHF 39.- (USD $44.50) delivered.
I haven't found any cheaper 300W PSU.
I didn't expect much but it works so far.
PROS
  • 4-digit display. Volt, Ampere and Watt.
  • Coarse and fine knobs for A and V separately.
  • USB charging socket.
  • GND (PE) output.
  • It reaches 30V and 10A with reserve (31.7V / 10.24A).
  • No overheating problems so far.
NEUTRAL
  • The fan is always running, so it's not "smart", but it is very quiet and runs at low speed.
    This is probably more pleasant than a fan that keeps turning on and off.
CONS:
  • Precise adjustment (4 digits) is difficult even with the "fine" knobs.
  • The accuracy is not so good that it would require a 4-digit display.
  • In the lower ampere range, the setting cannot be made without a multimeter. You can set the current limit so that you can, for example, power an LED without a resistor, but the display will then be at 0. It can not show as low as 20mA.
  • There is no on-off button for the output, but I have not seen any overvoltage when switching on.
  • Due to the design (SMPS) there is of course some noise, but I think it is within the normal range (20mV RMS in the example "noise.png").
    I'll try to reduce it as shown in the video when the capacitors are here.
A bit concerning: Whether the rear metal parts are grounded (PE) depends on the screw in "screw.jpg".
If this (accidentally) makes electrical contact with the back cover, the parts are grounded, otherwise not.
I scraped off the paint there to ensure contact.
“You get what you pay for”, but yes, it does what I expected and trying to improve cheap stuff is always fun.   ;)
Board Rev:20230518
« Last Edit: January 10, 2024, 10:44:18 pm by Aldo22 »
The following users thanked this post: DaneLaw, orzel
Offline madires
  • A qualified hobbyist ;)
Re: Longwei PDS-3010G
« Reply #1 on: January 28, 2024, 02:06:24 pm »
I would add a star washer.
« Last Edit: February 03, 2024, 08:53:34 am by madires »
« Reply #2 on: January 28, 2024, 02:22:41 pm »
I'd would add a star washer.
Yes, that's what I plan to do.
Offline tautech
« Reply #3 on: January 28, 2024, 07:48:54 pm »
NEUTRAL
Now load it to 50% and expect the fan to spin up some.  :popcorn:
« Reply #4 on: January 28, 2024, 08:49:07 pm »
Hmm, so far I've never heard the fan reacting in any way. It always spins at the same speed.
But it keeps the device cool enough, even under prolonged load.
Offline bobale
  • Country: cs
« Reply #5 on: January 31, 2024, 05:14:36 pm »
Where did you get it for such a low price?
Offline orzel
    • Sylphide Consulting
« Reply #6 on: January 31, 2024, 05:24:02 pm »
Probably on the official longwei store on ali ?
https://www.aliexpress.com/item/1005005489733374.html
« Reply #7 on: January 31, 2024, 05:46:43 pm »
Right. There was a sale around Christmas (USD 44.64)
Offline bobale
  • Country: cs
« Reply #8 on: January 31, 2024, 07:56:57 pm »
Unfortunately, it is much more expensive now with the shipping included.
Offline orzel
« Reply #9 on: January 31, 2024, 08:04:25 pm »
Weird, the shipping seems quite high. From here (France) it's 52.21€ with "free" shipping, and including 20% taxes.
« Reply #10 on: January 31, 2024, 08:27:41 pm »
Yes, prices change from country to country.
It's an opaque science.  ;)
For the EU, VAT is included in the Aliexpress price.
Not for Switzerland, for example. For postal imports, you only pay VAT from a total amount of CHF 65.
I don't know for Serbia.
It's difficult to compare.
« Last Edit: January 31, 2024, 08:31:12 pm by Aldo22 »
« Reply #11 on: January 31, 2024, 08:39:38 pm »
Doesn't it show you any shipping options when you click on "Shipping"?
« Reply #12 on: February 02, 2024, 02:28:58 pm »
After soldering in resistors and capacitors (47nF / 100V), the noise looks a little better (compare with the screenshot above).
Of course it is not perfect.
The following users thanked this post: orzel
Offline orzel
« Reply #13 on: February 02, 2024, 10:06:50 pm »
Ah, impressive. Check that the mosfets don't get too hot because of the change though.
« Reply #14 on: February 02, 2024, 10:36:06 pm »
Thank you.
Yes, I ran it with a 100W load for a while.
It didn't get any warmer than before, as far as I could see with the pyrometer.
But it's still an SMPS. It still has some noise. It is somewhat better than before.
