Baseband analog video tends to use 75-ohm as does digital video.
EDIT: And consumer RF (i.e. cable and satellite and antenna TV) uses 75-ohm.
Professional/scientific RF and the old 10Base2 coax ethernet used 50-ohm cable.
Actually, for very short jumper cables at baseband signals, there wasn't amy real problem wtih using 50-ohm coax for 75-ohm connections.
And back in the analog baseband video days, it was very common to see 50-ohm BNC connectors used everywhere, even for 75-ohm cable.
IME, it has only been in the era of HD digital signals (3G-SDI, etc.) that we are more conscientious about using 75-ohm BNC connectors.
