Author Topic: Look at this 50 ohm terminator. This isn't right is it?  (Read 16793 times)
Offline miguelvp
Re: Look at this 50 ohm terminator. This isn't right is it?
« Reply #25 on: October 26, 2014, 09:45:23 pm »
I use the same T-connectors regardless if i'm using 75 Ohm cables and terminators, or 50 Ohm cables and terminators.
They don't make different T-connectors for different frequencies so they must be physically the same.
Any variation might be vendor specific.
Offline Richard Crowley
  • KJ7YLK
« Reply #26 on: October 26, 2014, 09:53:11 pm »
Because of the absence of the white plastic dielectric mechanical support, the center contact of the female BNC connector is very fragile even when mating only with proper 75-ohm male BNC connectors.  I have had to use long-nose pliers to "reform" the contacts in many of my HD-SDI video gear.  75-ohm BNC connectors (of both genders) are significantly more fragile than the 50-ohm variety IME.
I have three $300 lengths of special flexible RG-6 cable which I use between my cameras and the video switcher.  Alas, when we set up the mobile system last week, one of those expensive cables is dead.  Now I have to troubleshoot it to find out what went wrong.  The connectors are fragile to begin with, but any improper kinking of the cable will deform the eye pattern bad enough to kill HD-SDI digital signals dead.
I am ordering a 75-ohm version of the W2AEW pulse generator to use TDR to try to find the cable fault.
https://www.tindie.com/products/land_boards/cable-tester-fast-pulse-generator-50-ohm/
Offline miguelvp
« Reply #27 on: October 26, 2014, 10:06:47 pm »
$300 cables? wow. And I complain when a coax is more than $1.50 per foot :)
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #28 on: October 26, 2014, 10:44:47 pm »
GEEK NOTE:
This is interesting to see a very minor problem that I had always been aware of - finally come into discussion.  It has always irked me that 'manufacturers' choose to use the wrong part - because it's cheaper or more convenient for them , and the dumb customers won't know any better... regardless of any chance of ''doing the job properly'' the first time. Finally !
This is often the reason first-world products are better made and more reliable than second- or third-world goods that are not specified or supervised by more experienced product teams.
The inferior products are not necessarily a bad idea or done wrongly - they are just made badly.
Don't ask a question if you aren't willing to listen to the answer.
« Reply #29 on: October 27, 2014, 08:05:21 pm »
If you want odd terminators look at waveguide terminators, which are basically a tapered waveguide filled with an epoxy and ferrite powder mix. They get nice and toasty in use with applied power.
Offline OilsFanTopic starter
« Reply #30 on: November 21, 2014, 04:06:31 am »
OP here. Haven't been in the forum for a while but it seems some interesting discussion ensued. Just to clear up my case, that terminator in the photo I posted was 50ohm. It was stamped in the metal on the back and had a green label stating 50 ohms. I went and exchanged it for a new one and all seems fine now.
Offline macboy
« Reply #31 on: November 21, 2014, 02:22:58 pm »
They are almost compatible.
The centre conductor pin diameters are different and from memory the 50 Ohm pin is likely to damage the 75 ohm female part of the connector and deform it beyond 75 ohm spec.
You may be thinking of N type RF connectors. Those are not mating compatible between 50 and 75 ohm versions.
BNC OTOH, differs only in the presence or absence of the dielectric in both the male and female ends. BNC was designed as 50 ohm and with the dielectric present, but it was discovered that leaving it out (using air instead) made it very nearly 75 ohms, so no other mechanical redesign such as pin diameter was necessary for the 75 ohm variant (unlike the N type).
Attached is a little picture I just took of a 75 ohm BNC coupler and cable with 75 ohm connector, plus 50 ohm variants for comparison. I have scores of 75 ohm BNC stuff because it tends to get dumpstered when Telcos redo their labs.
« Last Edit: November 21, 2014, 02:24:47 pm by macboy »
Offline IconicPCB
« Reply #32 on: November 22, 2014, 04:28:23 am »
While absence or presence of dielectric may indicate impedance level, there are slight differences between pins which do not preclude mating. Once mated ... well you know how it is.. pins may become distorted and structural return loss will be degraded meaning the connector is out of spec.
Offline edavid
« Reply #33 on: November 22, 2014, 04:42:37 am »
This is why it's better to use 50 ohm connectors for non-critical 75 ohm applications, like analog video.
Do you have any evidence for this claim, like a manufacturer's statement?  As far as I know, it is not true.
Offline IconicPCB
« Reply #34 on: November 22, 2014, 04:54:04 am »
Personal experience.
I used to work in what was known as HP product type 01 ( analogue instrumentation maintenance and cal dc-40GHz) in early eighties .
Also Google listings point to this difference and use of different dielectric materials in 50 and 75 ohm fittings.
Offline macboy
« Reply #35 on: November 22, 2014, 01:17:29 pm »
There is no physical difference between the mating surfaces of 75 ohm and 50 ohm. The slightly pointed vs. rounded tip of the pin seen in the photo is of no consequence, just a matter of preference of the manufacturer. This datasheet from Amphenol/Connex details all mechanicals of their 50 and 75 BNCs. There is no difference noted for any metal surfaces between 50 and 75 ohm variants. And this manufacturer states that "It is implicit in IEC 169-8 that 75 ohm BNCs made to comply with that standard will mate in a non-destructive manner with the 50 ohm BNC connectors described in IEC 169-8.... In over 15 years and a many million BNC connectors we have no first hand experience of incompatibility between 50 ohm and 75 ohm types, other than extremely rare (and very obvious) manufacturing faults."
Again, N type connectors are definitely not physically compatible between 50 and 75 ohm variants, and this leads a lot of people to believe, erroneously, that the same is true of BNC.
The following users thanked this post: 001
Offline IconicPCB
« Reply #36 on: November 26, 2014, 07:48:48 am »
Non destructive mateable does not mean identical.
While the catalogue listing may make that claim it does not support it with a dimensioned drawing of coaxial parts of the connector.
I would need to to see the dimensioned drawing in order to accept identical mechanical structures are involved.
Offline SL4P
« Reply #37 on: November 26, 2014, 11:49:23 am »
OK - now we have that out of the way...  make sure your connectors and cable are matched.    Solid core vs stranded, foil vs braid, diameter etc...
Offline flolic
  • Country: hr
    • http://filiplolic.com/
« Reply #38 on: December 15, 2014, 10:50:21 am »
Ever heard of 5 ohm terminator?  ;D
Few days ago I received SMA 50 ohm terminator from *bay (item no. 380319202322) which behave very strangely during some RF tests. Quick check with DMM showed it is actually 5.1 ohms resistor inside  |O
Words of wisdom, do not buy chinese crap, or if you do, triple check it...
Online Howardlong
« Reply #39 on: December 15, 2014, 10:56:07 am »
LOL! Do you have a picture of the mini tear down by any chance?
Offline flolic
  • Country: hr
« Reply #40 on: December 15, 2014, 10:59:40 am »
I will dissect it and post pictures when I get home  ;)
Offline tautech
« Reply #41 on: December 15, 2014, 11:30:23 am »
Hacksaw? Grinder? Big hammer would be my recomendation.  >:D
Get some decent 50 Ohm Feed-throughs and be done with it.
It doesn't take much of a demanding waveform to demonstrate how poor the performance of tee's and terminators is.  :palm:
Compare and see for yourself.
Got my pair of Tek 1x & 10x many years ago, think I paid US$30 for them both off eBay and it sure hurt at the time.
But quality lasts and knowing that, the price is forgotten in time.
Or a scope with 50 Ohm inputs.  :box:
Online Howardlong
« Reply #42 on: December 15, 2014, 11:35:09 am »
Not sure if you'd be intending to use an SMA terminator for use as a scope terminator, more likely it's for an RF application.
Offline flolic
  • Country: hr
« Reply #43 on: December 15, 2014, 01:08:15 pm »
Haha, I would like to use hammer, but I also want to see what's inside.
I have one of these (http://uk.rs-online.com/web/p/rf-terminators/5464695/), it's enough for my scope needs.
Offline flolic
  • Country: hr
« Reply #44 on: December 15, 2014, 06:41:22 pm »
As promised, tear down images  ;)
To be honest, I expected worse than this. Center pin is soldered to resistor and plastic insulator is made of PTFE. It does not melt when heated with soldering iron.
Resistor ground connection is by contact pressure.
There is only one "small" problem, wrong resistor value  ;D
  • KJ7YLK
« Reply #45 on: December 15, 2014, 06:46:25 pm »
50 ohms is NOT a standard resistor value, even in the E192 series
Offline c4757p
  • adieu
« Reply #46 on: December 15, 2014, 06:47:57 pm »
Richard: he said 5.1, not 51!
Also, SMA is usually used at rather high frequencies - no way in hell that cheapo axial is still a resistor above 100 MHz or so...
  • KJ7YLK
« Reply #47 on: December 15, 2014, 06:50:18 pm »
Looks like Green - Brown - Black to me.  = 51 ohms.  Who said anything about 5.1?  That would be absurd.
I would have expected better "termination" of the ground side of the resistor, though.   :palm:
If that resistor is 5.1 ohms, then is is marked incorrectly.
« Last Edit: December 15, 2014, 07:06:22 pm by Richard Crowley »
Offline c4757p
  • adieu
« Reply #48 on: December 15, 2014, 06:55:34 pm »
Green-brown-black-silver-brown, dude! 510 * 10^-2 ± 1% :P
Offline flolic
  • Country: hr
« Reply #49 on: December 15, 2014, 06:59:36 pm »
Yap, that's 5.1 ohm resistor  :D
