So I don't need to consider the EEVBlog BM-235 anymore, as I bought it late last night, should have it by Wednesday.
Though I think I will go ahead and buy a ANENG meter as well, maybe a couple more as gifts to some family, while I am at it. Sometimes shopping for myself makes shopping for others easier.
Again as I am a newb I don't know how to appreciate the differences in feature set. On my current meter I was mainly using continuity, resistance, and voltage. I don't think I have used mA, though plan on using it for testing. Though switching manually between ranges is really annoying.
I think Fungus brought up some good points about the Fuse size, granted I do not appreciate nor understand the importance size of fuses. I have only really handled 120v breakers in a breaker box and use 15amp breakers for 14awg, while I use 12awg for 20amp. I also follow the requirements for replacing a fuse in my vehicle. I understand how the breakers work and understand the sizing and reasoning. Though will need to look into the reason for different sizes and various "single" use fuses.
I do have a small hand size NCV, though it is a cheaper HF so it could break. So maybe a NCV would be helpful. I don't how I would use a square wave output, so I don't know your thoughts on that. I also do see Fungus's point about the advantages of having separate sockets for mA and Amps. This way I guess I won't accidentally blow a fuse. At least not as easily.
Right now I am planning on buying the AN870, for the underlined reasons. My biggest hesitation is that so many people who know more than me use the AN8008, though I wonder if it is because the AN870 is so new and the price use to be a lot more, that not a lot of people have purchased it. On paper the AN870 seems a lot better. The time it takes to ship isn't a huge thing as I have my old meter and will be getting the BM-235 on Wednesday.
I was looking at these reviews:
AN870: https://lygte-info.dk/review/DMMAnengAN870%20UK.html-Temp Sensor
-NCV
-Fuses size: 6x30mm (.8mA)-Display 20000
-$30 shipped via China & NA via Amazon
-Separate mA and A socket-Larger Size
-No Missing RangesAN8008: https://lygte-info.dk/review/DMMAnengAN8008%20UK.html-Wave Ouput
-Fuses size: 3.6x10mm (.2mA)
-Display 10000
-$20 via China & $23 2day via Amazon
-Compact size
-Missing 99.99mA and 9.999mA ranges
AN8009: https://lygte-info.dk/review/DMMAnengAN8009%20UK.html-Temp Sensor
-NCV
-Display 10000
-$22 via China & $31 2day via Amazon
-Compact size
BSide ZT301: https://lygte-info.dk/review/DMMBSide%20ZT301%20UK.html-Temp Sensor
-Display 8000 (Lowest of the lot)
-Fuses size: 5x20mm (.2mA)-$20 via China & $23 2day via Amazon
-Compact size
-Separate mA and A socket-Has 82.00mA and 820.0mA range
-Less accessories than ANENG
BSide ZT302: https://lygte-info.dk/review/DMMBSideZT302%20UK.html-Wave Ouput
-Display 10000
-Fuses size: 5x20mm (.2mA)-$24 via China & $28 2day via Amazon
-Compact size
-Separate mA and A socket-Missing 99.99mA and 9.999mA ranges
I might purchase 3 or 4 of the same unit as gifts for family. You can always use a decent multi-meter and get x-mas shopping out of the way.
Edit: Added ZT30X for comparison.
