I think your funds will not be enough until someone hacks DS1074 into higher bandwidth (which may or may not be possible). Difference between 70 and 100MHz model of DS1000Z series is quite likely only software lock. For 200MHz it may not be the case, and may not even be possible due to hardware limitations (there's no official model with BW higher than 100MHz).
