I picked up an old HP 4271B (digitl readout one MHz LCR) for $20 at a Hamfest. After a week of putzing around I think it is fixed. It reads reasonable values on all ranges.
Problems were mostly the relays.
I was wondering if anyone has any suggestions for a Test Fixture. I wonder if one could be easily fabricated?
I believe the normally grounded side of the in/out BNCs is isolated at the 4271 chassis, so I thought I would use a plastic box and mount four male bulkhead BNCs to that.
Or would it matter if the BNCs were all common at this point? (metal box)
I was thinking of using a big Zif socket for the wired components, one side being in and the other out, component could go into any in and out combo..
Was also thinking of using a little SMD pad, like the ones on cheap component testers for SMD parts. Maybe fabricating a little lexan lid on a hinge to hold the components down.
A setup with both could be easily made. Or is this too much surface area and make readings difficult?
About the wiring, should I try to use coax in the fixture box or is this overkill?
Any comments would be welcome
Wally KC9INK
