It is to calibrate a RPM indicator which is connected to a Tach Generator. The indicator measures the frequency, but increases the minimum voltage with higher frequency. That is why 20Vpp is not enough, I need a bit more.
It has to be a solution out of the box, as it will be used in the field.
