Author Topic: Bus Pirate 1 Mbaud uart.  (Read 1666 times)
Offline firewalkerTopic starter
  • Country: gr
« on: July 12, 2018, 11:57:23 am »
 Today I had to test a serial connection of 1 Mbaud. The only available 1 Mbaud capable USB<->serial adapter I had was the TF323R on a Bus Pirate.
It's fairly easy to set it up like a transparent bridge on 1 Mbaud, but it seems the speed between TF232R an the PIC 24F is at a fixed 115,2 kbaud?
PC USB <---115,2 kbaud---> PIC 24F <---1 Mbaud---> Serial Device
Is that correct? I can't use a true 1 Mbaud bridge?
Alexander.
  • Country: gr
Re: Bus Pirate 1 Mbaud uart.
« Reply #1 on: July 12, 2018, 03:29:04 pm »
For everyone interested, i can be done by making source code changes.
uart.c:55
const uint16_t UART_BRG_SPEED[] = {
    13332, /* 300 bps */
    3332,  /* 1200 bps */
    1666,  /* 2400 bps */
    832,   /* 4800 bps */
    416,   /* 9600 bps */
    207,   /* 19200 bps */
    103,   /* 38400 bps */
    68,    /* 57600 bps */
    34,    /* 115200 bps */
    127,   /* 31250 bps */
To:
    832,   /* 4800 bps */
    416,   /* 9600 bps */
    68,    /* 57600 bps */
    3      /* 1000000 bps*/
main.c:171
  /* Set the UART port speed to 115200 bps. */
  bus_pirate_configuration.terminal_speed = 8;
To:
  /* Set the UART port speed to 1000000 bps. */
  bus_pirate_configuration.terminal_speed = 10;
« Last Edit: July 12, 2018, 03:33:23 pm by firewalker »
Offline ricktendo
  • Country: hn
« Reply #2 on: July 12, 2018, 03:32:51 pm »
Sorta Off Topic: but can Bus Blaster also be used as UART?
  • Country: gr
« Reply #3 on: July 12, 2018, 03:39:25 pm »
I don't know.
Alexander.
