Author Topic: Looking for Tektronix TLACAL Files on Application Install CDs V5.6, V5.7 or V5.8  (Read 607 times)
Offline calibrationfixtureTopic starter
This Software isn't available on www.tek.com  (with one exception, see below), but can be found separately on the TLA Application Install Disks. I allready have TLACAL V4.4, V5.1 and V6.0. V6.0 (downloadable from tek) doesn't support the TLACAL2 (P6800 Series) and TLACAL3 (P6900 Series) Fixtures to the same extent as the earlier V5.1 and V4.4. Hoping that TLACAL V5.6, V5.7 or V5.8 support the later introduced P6960DBL, P6962DBL, P6960HS and P6962 Probes.
Is anybody in the possession of these?
Calibrationfixture
« Last Edit: January 14, 2023, 07:11:57 am by calibrationfixture »
Thank you for your reply, but these don't contain the TLACAL Files. Only TLACAL V6.0.213.0 is listed. The only source for this Software are the original Application Software Install Disks. The way I acquired V4.4 and V5.1. The last with the help of others.
Greetings,
Calibrationfixture
« Last Edit: January 17, 2023, 06:19:06 am by calibrationfixture »
