i would say a scope is not the ideal tool, i do use saleae tools to monitor voltages and data lines, and longer periods by usb Ni-DAQ interfaces, i scan 12 channels over 24 hours
but it give tons of data, i mean tons, it has a tendency to be heavy on the computer ressources, you need a good pc / laptop for that
A scope memory will overfill and not provide you with what you need, it may stream lot more data than needed, and many scope softwares are not designed for the very long run you need unless you save on csv files .... or save as a graph ?? or build your own with python etc ....
