Author Topic: Looking for Weller solder iron cable  (Read 1603 times)
Offline mkiijamTopic starter
« on: November 12, 2022, 07:19:50 pm »
Anybody know what the stuff is called on the old-school Weller solder iron pencils? over the years I have had to cut mine down, but I love the original cable!
Online Martin72
  • Testfield Technician
Re: Looking for Weller solder iron cable
« Reply #1 on: November 12, 2022, 09:13:35 pm »
Which model ?
Online Martin72
« Reply #3 on: November 12, 2022, 09:39:24 pm »
Then it´s for the TCP Magnastat irons, it´s a silicone sleeved cable.
Sparepart example:
TCP-S Cable
« Reply #4 on: November 12, 2022, 09:57:00 pm »
Thank you!
I'm hoping to find it in bulk.
Online Martin72
« Reply #5 on: November 12, 2022, 10:01:50 pm »
In bulk ?
Offline Arts
« Reply #6 on: November 12, 2022, 11:06:15 pm »
I used to grab the damaged irons from work and salvage those silicon cables to make double-length irons for field work. That sure was some sexy cable :)
Offline factory
« Reply #7 on: November 13, 2022, 01:35:21 pm »
Not sure why you would want a bulk reel of it, the newer Weller irons we had at work failed due to the cores perishing, they went hard & crunched to bits causing short circuits inside the cable, exactly as you find with some ancient rubber insulated cables.
Offline Messtechniker
« Reply #8 on: November 13, 2022, 01:48:02 pm »
Just the same with the original white cable of the Weller WECP-20 .
Replaced it with some black silicone cable (source no longer available)
a while ago. Still going strong. :)
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Offline yo0
  • Country: mx
« Reply #9 on: November 13, 2022, 03:29:14 pm »
You can use bare microphone professional silicon cable at the musician stores.
Best regards
Offline factory
« Reply #10 on: November 14, 2022, 09:09:26 pm »
Strangely the older Weller irons never seemed to suffer this problem, can't remember the Antex or Pace irons having this problem either. Ended up transferring the heater/switch assembly to one of the broken older Weller irons.
All gone now though, since work downsized the lab. They only have an Antex iron & Pace desolder station left, which hopefully will get replaced with a combined Metcal unit, as the Pace is getting knackered and a pain to maintain due to work refusing to buy from Farnell, the Pace ended up with the vacuum pump from a dead Weller, as the motors failed in two base stations.
« Reply #11 on: November 17, 2022, 12:37:00 am »
Bulk! Yes, so I can make a 10ft length! :-)
Yeah... it's the older stuff. It never kinks, never melts, never breaks, never twists. Always finds the bad components and makes me sandwiches.
