Not sure why you would want a bulk reel of it, the newer Weller irons we had at work failed due to the cores perishing, they went hard & crunched to bits causing short circuits inside the cable, exactly as you find with some ancient rubber insulated cables. David
Quote from: factory on November 13, 2022, 01:35:21 pmNot sure why you would want a bulk reel of it, the newer Weller irons we had at work failed due to the cores perishing, they went hard & crunched to bits causing short circuits inside the cable, exactly as you find with some ancient rubber insulated cables. DavidJust the same with the original white cable of the Weller WECP-20 .Replaced it with some black silicone cable (source no longer available) a while ago. Still going strong.
