If that's your budget, I would look seriously at the Siglent SDS2000X Plus. It's €1,199, and has the 2000 level features but only 2 math channels (instead of 4), and it's 8bit instead of 12bit. It also has a built-in AWG. I would buy that again ten times before looking at the lower models that include 12bit.
The 2000x plus has even 10 bit resolution up to 20 ish MHz.
And a really good input front wrt noise, so good for audio.
Exactly. I used it for audio for 3.5 years before I upgraded to the HD model (which I only did because a ridiculous opportunity slapped me in the face). It was almost always in 10bit mode, and did really well.
I dont really know as i have never used a digital one
But i guess people are talking about the speed of the interface? Opening menus etc… please correct me if im wrong as im really not certain. But any kind of latency in menus would be a nogo for me. I hate how slow this digital age feels - everything has latency
This would be way more important to me than specs. I just called my old electronics guru (broadcast guy) and he said 20 Mhz is all i need
The interface isn't slow at all. It's not as fast as the more expensive HD model, but it's by no means slow in its own right.
Most scopes, especially less than $3000+, have a relatively slow FFT. Some brands may be marginally better than others, but none are worth bragging about. Unless you spend a minimum of $1000 more on your scope, you won't really see better FFT or Bode plot performance.
This is where a proper analyzer like the QA403 comes into play. It will allow you to run specific tests for audio faster than any of the scopes we're talking about. And it's only about $600. So now you have 2 excellent tools instead of 1 that would cost more money and really isn't better for your needs.
The only reason not to buy the 12bit version for the scope is that it's probably not worth an extra $1000 to you right now. Maybe it is, compare them. 😉
