The Beehives are good. The owner of the company is former HP/Agilent who was involved in their near field probe designs. He is very helpful if you need information or application help.
You can also make your own and they can be quite good. Just the right size and with good E-field rejection if you're careful, with semi-rigid coax.
The E-field probes are simply an exposed length (like 6mm for instance) of coax center with insulation.
By simply looping 0.085 center conductor back to the shield (i.e. loop diameter 0.040 - ish) I've mapped H field emissions off the top of an FPGA very precisely, fixed with self adhesive absorber.
I apologize ... did not answer the original question
