Author Topic: Low cost logic analyzer probe for Rigol MSO5000 EasyEDA project  (Read 87067 times)
mosafet and 2 Guests are viewing this topic.
Offline crgarcia
  • Country: ar
Re: Low cost logic analyzer probe for Rigol MSO5000 EasyEDA project
« Reply #100 on: March 10, 2022, 09:11:59 pm »
yes, I guess I have no option but to buy the 400usd original component. Anyways, thanks a lot for posting and sharing this project. It's super useful! :-+
Offline Peter_the_diver
« Reply #101 on: March 19, 2022, 08:25:07 am »
Hello Guys,
I have built and tested a few couples of samples of my design 3.0. Everything works fine. Find attached some pictures
1443283-0
Two things are infinite, the universe and human stupidity, but I'm not quite sure about the universe yet.
Albert Einstein
The following users thanked this post: S. Petrukhin, rdtsc, OHR
« Reply #102 on: March 19, 2022, 08:30:13 am »
and here some more..
1443289-0
Albert Einstein
The following users thanked this post: OHR
Offline Factotum
  • Trying to realize my potential.
    • Factotum Industries
« Reply #103 on: May 17, 2022, 07:56:50 am »
Is there a link for the v3.0 PCB and BoM?
Cheers!
An artist trapped in a scientist's body.
The following users thanked this post: NRS63
Offline ebclr
« Reply #104 on: May 17, 2022, 10:14:49 am »
I just bought the original chip, From China , let  wait to arrive
Offline S. PetrukhinTopic starter
  • Country: ru
« Reply #105 on: May 17, 2022, 12:30:23 pm »
Original CHIP or Rigol probe for $400?
If there is a probe, then you will have beautiful wires.  :-DMM
I was offended to buy it for half the price of an oscilloscope, and I also regretted the money.
And sorry for my English.
Offline ebclr
« Reply #106 on: May 18, 2022, 10:18:50 am »
I'm talking about the Ti Chip
Offline raminrajabi
  • Country: ir
« Reply #107 on: June 25, 2022, 06:40:01 am »
Can I use it for my ds1104z plus oscilloscope?
I think my oscilloscope and yours using the same device  :-BROKE
Thanks
  • Country: ru
« Reply #108 on: June 25, 2022, 07:17:48 am »
Thanks
Yes, but you need to take care of the connecting wire to the other connector.
Offline raminrajabi
  • Country: ir
« Reply #109 on: July 20, 2022, 05:29:26 am »
I think both oscilloscope using the same module, so same connection? Right?
Offline vermin123
  • Country: ru
« Reply #110 on: July 23, 2022, 07:49:04 am »
For those who are looking for sn65lvds1dbvr - https://aliexpress.com/wholesale?SearchText=sn65lvds1dbvr
But I already bough 6 x sn65lvds391  |O, so will make my board with it...
  • Country: ru
« Reply #111 on: July 23, 2022, 07:58:40 am »
And not only oscilloscopes.  :) This is a common LVDS interface, widely used.
Offline JCS666
    • ea1dzl
« Reply #112 on: August 24, 2022, 11:39:48 am »
I am interested in this kit, does anyone sell it?
  • Country: ru
« Reply #113 on: August 24, 2022, 12:39:39 pm »
Perconally I can't help you - all logistics from Russia to Europe has been destroyed.
But you can order PCB and assembly on JLCPCB or PCBWay, for example. It's not difficult.
The following users thanked this post: crgarcia
Offline imolnar
  • Country: hu
« Reply #114 on: October 05, 2022, 01:22:36 pm »
Hey guys,
I built a version of this DIY LA.
My scope doesn't recognize, when I plug it in.
The outputs of the DS90.. are fine, but the scope indicates a constant low level.
  Any advice?
  • Country: ru
« Reply #115 on: October 05, 2022, 04:49:33 pm »
Hey guys,
  Any advice?
How did you check the LVDS outputs? This is a differential signal, it does not need to be measured relative to gnd, it is the voltage between pins 3 and 4 that is needed. It should change when applying 1 to pin 5.
If this does not happen, the power supply may not be supplied or the chips are faulty.
And it is absolutely necessary to check the flat cable - whether it is properly compressed (it should be 1:1, pin to pin, the keys on both connectors should be in the same position), there is contact on all wires.
Did you remember to turn on LA in the oscilloscope?
This is a very simple circuit, I'm sure you'll find the fault.
Offline mrpea
« Reply #116 on: November 08, 2022, 02:52:37 am »
S.P,
just a quick question, how did you generate the board view for this project? i have been using altium to generate PCB files and have not seen a board view quite like that.. very handy for loading a board manually. i searched easyeda's wiki and didn't see anything..
  • Country: ru
« Reply #117 on: November 08, 2022, 07:43:31 am »
S.P,
To get BoardView and a few other very nice features in EasyEDA, you need to install pragins.
Start browsing here: https://easyeda.com/forum/topic/Extension-User-Extensions-for-EasyEDA-Summary-9e065b68316f4491a3911dc6204be31e
Altium is too expensive and cumbersome thing, I don't use it.  :)
Offline mrpea
« Reply #118 on: November 08, 2022, 10:12:43 pm »
Thanks for that.. I have been using Altium for the past 15 years, i have tried to use EasyEDA and KiKad, but i keep trying to use the fast keys for Altium.. i really need to do a full project in either to become more proficient.
  • Country: ru
« Reply #119 on: November 09, 2022, 12:54:53 am »
You can import a project from Altium into EasyEDA and generate a BoardView.  :scared:
Offline imolnar
  • Country: hu
« Reply #120 on: January 12, 2023, 10:21:40 am »
What voltage should be measured on the unloaded ProbeDet pin?
  • Country: ru
« Reply #121 on: January 12, 2023, 10:57:58 am »
Approximately 3.3-5 volts.  :)
Offline imolnar
  • Country: hu
« Reply #122 on: January 12, 2023, 12:13:16 pm »
0.4V by me.
  • Country: ru
« Reply #123 on: January 12, 2023, 12:32:39 pm »
0.4V by me.
0.58V
If short this pin to GND, "Probe connected" message will show about 3 seconds.
Offline imolnar
  • Country: hu
« Reply #124 on: January 12, 2023, 12:54:49 pm »
There are no messages on my scope. I can press the LA button, but there is no change in the digit channels. :(
