Author Topic: Low Current DC Clamp Meter  (Read 25638 times)
Offline mcinque
  • I know that I know nothing
Re: Low Current DC Clamp Meter
« Reply #25 on: July 05, 2015, 08:40:24 am »
I suggest PICO TA018, it's relatively cheap (€ 150) and has a good sensitivity and a better rejection noise than its previous version. I acquired it recently, and I'm very satisfied.
100mV/A on 20A range, so 10mV/100mA with 10mA minimum sensitivity (but it's readable even with 5mA), should fit your needs
10mV/A on 60A range
http://www.picoauto.com/current-clamp-small.html
« Last Edit: July 05, 2015, 08:42:12 am by mcinque »
Offline 0xdeadbeef
« Reply #26 on: July 05, 2015, 10:21:45 am »
Looks like a rebranded CA-60 which is sold under different brand names.
Also the Hantek CC-65 seems to be a very close relative.
Offline mcinque
« Reply #27 on: July 05, 2015, 02:17:03 pm »
Probably, until your post I was convinced that Pico doesn't do rebranding  :-// Is this a known behavior of Pico? Or who's rebranding who? (Or who's copying who?)
EDIT: Found that TECPEL seems to offer his UNI-T UT81 (http://www.tecpel.com/Oscilloscope-multimeter-OS-81B.html) or it's UNI-T that rebrands TECPEL?
Also Tenma offers a rebranded UT81, don't kow if TECPEL or UNI-T. The rebranding is a very disappointing thing.
« Last Edit: July 05, 2015, 02:22:16 pm by mcinque »
Offline 0xdeadbeef
« Reply #28 on: July 05, 2015, 02:36:34 pm »
Yeah, it's all a big mess. I also noticed that this Tecpel DCM-043 looks exactly like the "GTC CM100" mentioned earlier in this thread.
I sometimes wonder if at least all these Chinese and Taiwanese companies know who copies from whom. But honestly I tend to think they lost the overview as well.
Offline Rupunzell
« Reply #29 on: July 05, 2015, 03:55:06 pm »
K100 & K110 might use a flux gate as a measurement device. Both have a percent of reading and + or -  150 to 200 uA ( 1mA/mV or 1mA/10mV) added tot he reading making both not very accurate at the 1mA range. With that much error, both would be more of an indicator of current than accurate measurement.
Measurement error is further increased by the accuracy of the instrument used to make mV measurements. Accurate measurement of millivolts is no easy task for any volt meter. Then there is stability and drift to deal with.
K100
http://www.aemc.com/products/pdf/1200.67.pdf
K110
http://www.aemc.com/products/pdf/2111.73.pdf
Beyond this, noted at the bottom of their spec sheet is absence of magnetic fields. This likely means the flux gate sensor is not well shielded and subject to stray field pick up and there appears to be no compensation for the Earth's magnetic field.
Sensing device type alone does not give an inherent measurement advantage unless the design, implementation, construction has the required details to make it a truly useful instrument.
Bernice
AEMC K100 provides 1mV/mA output signal and can measure from 100uA to 4.5A DC.
http://www.testequipmentdepot.com/AEMC/accessories/current-measurement-probes/ac-dc-microprobes/k100.htm
BTW, K100 uses flux gate magnetometer technology, just like HP 428B.
http://www.aemc.com/products/html/view.asp?id=204&dbname=products
[/quote]
« Last Edit: July 05, 2015, 04:22:11 pm by Rupunzell »
Offline Mike WarrenTopic starter
    • Personal Website
« Reply #30 on: July 08, 2015, 03:52:21 am »
The Altronics meter arrived today. It's definitely identical to the CEM DT-337 that MJLorton reviewed.
I'm not impressed with it; build quality and UI quirks, but I think it will do what I want.
Looking inside, it seems they forgot that CAT III 600V meters are supposed to have some sort of input protection.
Offline PTR_1275
« Reply #31 on: July 08, 2015, 04:07:27 am »
That's a shame.
I don't think I've ever used my clamp meters for voltage readings before. I just checked my der ee and finest clamps and both are rated cat 2 600v. I wouldn't trust the der ee at 600v but I've not looked inside at input protection.
How does it go with current accuracy / resolution?
    • Personal Website
« Reply #32 on: July 08, 2015, 04:19:39 am »
I won't be using this one for anything other than DC current, so it doesn't matter to me. I just opened it up because I thought some people here might be interested.
Much like the results Martin gets. It's finicky to get right. The zero button is a latch. That just doesn't make sense. You have to tun it off and back on before each reading.
As well as testing it on the bench, I tried it on 9 cars we have here. A couple of them have battery cables that are too thick for the clamp. I found the best accuracy was obtained by holding the meter right next to the cable I wanted to measure, zeroing the meter, and then clamping it on, keeping the angle the same as it was while zeroing it.
Offline retiredcaps
« Reply #33 on: July 08, 2015, 05:51:31 am »
Thanks for sharing pics of the insides.  Martin never showed the insides in his video.
The green component by the flat flex connector might be a MOV (varistor)?  That yellow component is a PTC and labelled as such.
« Last Edit: July 08, 2015, 06:21:31 am by retiredcaps »
