Author Topic: Low Z Mode power dissipation?  (Read 473 times)
Offline Phoenix6478
  • Country: at
« on: August 21, 2018, 10:42:05 pm »
Hello
I have got a question regarding the low impedance mode on multimeters like the Fluke 289:
The manual of the Fluke 289 states that it has an input impedance of 3kohm in the low z mode and it can go up to a 1000V. But if i measure for example 1000V, there will be a current flow of 333mA through the meter at 3k according to  ohms law. But 0.333A at 1000V leads to a power dissipation of 333W. That is quite a lot of power to dissipate inside a multimeter.
So how exactly does the multimeter handle the current flow? Is there a detection feature which switches to the usual 10Mohm impedance if the voltage does not drop down like in the case of ghost voltages?
Greetings,
Phoenix
Offline exe
  • self-educated hobbyist
Re: Low Z Mode power dissipation?
« Reply #1 on: August 21, 2018, 11:16:17 pm »
I think they use PTC, 3kOhm only in cold state :). At least 121GW works this way.
Offline Phoenix6478
  • Country: at
« Reply #2 on: August 21, 2018, 11:26:19 pm »
Thank you for your reply  :)
Using a PTC makes a lot of sense. As soon as the current starts to flow it starts to heat up and its resistance increses. The current gets limited by the rising resistance.
Offline pigrew
« Reply #3 on: August 21, 2018, 11:37:53 pm »
Joe Smith on YouTube just posted .  I assume the 289 had a similar setup.
The following users thanked this post: Marco1971
Online David Hess
  • DavidH
« Reply #4 on: August 22, 2018, 05:29:53 am »
It might also use a high voltage constant current shunt like a couple of depletion mode MOSFETs so the resistance increases proportionally to voltage.
Offline mqsaharan
  • Country: pk
« Reply #5 on: August 22, 2018, 06:54:23 am »
Hi Phoenix6478,
Please take a look at HKJ's review at http://lygte-info.dk/review/DMMFluke%20289%20UK.html. He has covered the answer to your question very nicely in the form of a graph. He is also a member here on EEVblog.
Regards,
Qasim.
« Last Edit: August 22, 2018, 01:57:39 pm by mqsaharan »
