I've been searching/researching and scratching my head for a while, but couldn't come up with an answer to this.
I got an M-830B as part of a tool set. The meter looks exactly as on P. Vis's page
inside, the only difference being that mine is black. I've looked at schematics floating around the 'net and they don't seem to match the PCB.
The problem that I've encountered is that the meter should (and I know that these meters can) show the same voltage regardless of polarity. However, the one I have is a few counts off when polarity is reversed. E.g., it would display 5.00V, and then reversing the probes would show -4.98V. Not a big deal for such a cheap meter, of course, but I'm sure there's a way to balance this out. Any suggestions would be welcome, and also, maybe a place to find the correct schematic.
