Yes, that also caught my eye in a very positive way.
Oh yes, to this day I haven't opened the scope and I won't be doing so either.
Meanwhile, I played around with the generator a little.
The rectangle goes up to 25 MHz.
Then I took a picture of a 1 MHz sine wave and its FFT; the second harmonic is at -60 dBm, which I think is good.
And then, of course, there's the Bode plot...
There are some interesting settings in the menu, such as the plot “Strategy.”
You can choose between “Fast,” “Balanced,” “Low Noise,” and “Ultra Low Noise.”
Ultra Low Noise is for very patient people; a plot with the maximum number of points per decade (500) takes 4 hours and 7 minutes—I measured it...
“Balanced” takes about 12 minutes, “Fast” about 8 minutes.
I used the low-pass/band-pass function of the demo board as a test object.
