Hello,
I don't know how are expensive leads.
I make my own from (1)silicon wire (2)awg14 [or awg16, 14 is slighty better] with(3)Chinese banana 4mm-32A jacks (with screw) and (4) Chinese insulated alligator clips.
(1) silicon wire is much nicer too use. Since I discovered it, now I build all my leads with this silicon wire.
(2) awg14 has an incredible low resistor per meter, awg16 is very good. The most resistor wire is a low-price alligator clip at about 1.5Ohm and 1.5eur on ebay.
(3) these alligator have a "nose" with springs and can also be use as female banana (but not insulated in this case).
(4) fully insulated are clever for resistor measures. Our fingers can't change the resistor measure. It isnot small alligator with a soft skin, but a 55mm long one.
I already use more than 10m of these awg16 and awg14 wires. Cable I lost, little gifts, and so.
Price is about 1-1.5eur per meter. banana 4mm 0.4eur x 4 for a wire, 0.6eur x 2 for aligator clips : A couple of two leads cost maybe 5eur each.
Have a nice day, without viruses for you and your family.
