I own a three versions of the venerable Marconi 2022 RF sig Gen.
These Sig Gens are still sought after due to their compact size and decent performance. The most common fault on them
is failure of one of the Philips OM series gain block hybrid amplifiers. Those hybrid amplifiers were common and relatively inexpensive in the 1980's. They were cheap enough to be used in TV aerial booster amplifiers as a gain building block component. Sadly their relative rarity in the modern world has made them somewhat more expensive. I have a 2022 that has suffered failure of many front panel button switches and that is a project that I will get around to doing when time permits.
For information, the 2022E model was specified by the UK MOD who needed a tactical field use signal generator which did not have a long settling time before producing a stable output frequency. The OCXO was ditched and a TCXO employed to meet that fast set-up and use requirement. For the MOD application precise frequency accuracy was less important than the speed with which the unit became frequency stable. I personally like my 2022E as it is portable, fast to use and its accuracy is more than enough for most tasks that I have for it. If not, I connect a small Quartzlock 2A off-air frequency standard to it that uses the BBC Radio 4 198KHz carrier as its reference.
From memory I own two 2022's, one 2022C and one 2022E. I was going to sell one or two but could not bring myself to do it as I have used these a lot in my career and I have a soft spot for them. I sold my bulky Marconi 2019 RF signal Generator instead.
I believe that I may also have the service manual for the 2022E model, but sadly I am many thousands of miles away from home for a while so cannot check.
Good luck with the restoration
Fraser
