Most LCR meters can't do in-circuit tests. The Mastech has a test voltage of 500mV peak to peak, which can cause false readings due to turning on transistors, most testers capable of in-circuit readings are around 100mV. Keep in mind none of the in-circuit meters are particularly accurate either.
