Author Topic: Are these Chinese ethernet/coax testers any good?  (Read 1182 times)
Offline dorkshoeiTopic starter
« on: January 15, 2021, 09:40:24 pm »
https://www.aliexpress.com/item/2044442346.html
I can't imagine the coax portion would be useful here in the USA as cable-tv is RG6/RG59 75 ohms.
I couldn't see a combined ethernet+RG6 tester on AliExpress.  Just ethernet+bnc.
Offline CJay
Re: Are these Chinese ethernet/coax testers any good?
« Reply #1 on: January 15, 2021, 09:47:44 pm »
It's not going to measure cable impedance, it's just a basic continuity tester so it'll work just fine on 75, 93, 25 or whatever impedance coax as long as you stick a terminator resistor across the end of the cable.
« Reply #2 on: January 15, 2021, 10:41:06 pm »
In the listing there is an image where it's showing impedance.
Offline JohnnyMalaria
    • Enlighten Scientific LLC
« Reply #3 on: January 16, 2021, 01:56:02 am »
It's not intended for CATV etc. It's meant for networking.
Here's the manual (with different branding): https://sgcdn.startech.com/005329/media/sets/REMOTETEST_Manual/REMOTETEST.pdf
Offline CJay
« Reply #4 on: January 16, 2021, 08:43:42 am »
No, there isn't, there's an image where it shows you it can tell if there's a terminator attached.
It's measuring terminator impedance (and probably only well enough to tell if it's got one or two terminators attached) not cable impedance.
Online radiolistener
  • Country: ua
« Reply #5 on: January 16, 2021, 10:00:22 am »
This is not display :) This is just a sticker with label near led.
Offline ralphrmartin
    • Me
« Reply #6 on: January 16, 2021, 07:29:58 pm »
Going off beam a little, I got one of these for testing my PoE Ethernet, and it seems to work OK for the price.
https://www.aliexpress.com/item/1005001737031111.html
Can't comment on coax as my only piece of coax runs up to the roof where I can't get at it anyway.
