Greetings
This is my first review.And i'm a newbie in electronics.Sorry for my English,i know it is poor.
Let's get to work
Mastech MS8239c - 4000 counts,600V CAT III,update rate i think is more then 3 times per sec,is not TRUE RMS
The DMM Mastech MS8239c does not have strengths,only the price 19 dollars.
Packaging
The carton box is nicely,inside we find the multimeter,test leads(decent,more flexible than UNI-T,total length 80cm),K-Type Thermocouple,manual,no battery (works with 2 x 1.5V AAA)
1.MS8239c it has a removable holster which is flexible.The meter stay nice and secure in holster (solid like a rock)
2.The screw to open up the battery compartment is metal threaded
3.The input jacks are split
4.Both fuse are rated 600V.The maker is ASTM.Dimensions : 6.3 x 32mm
Internal protection
The internal protection is weak.Only 2 PTC,some resistors and a diode bridge
Bad design
1.On the PCB we find the current shunt which is very close by conductor (COM)
2.The conductor of A jack touches the socket of 10A fuse
After this i put heat shrink tubing on all input jack
3.The selector switch contact have a type of grease on them ( i acted correctly by cleaning the contact?)
Display
Is bright enough
The display passed the known external pressure test
Back light is powerful and uniform
If you press the back light button, the light will stay permanently on (it has no timer)
Auto-Power-off
In manual says -after 30 minutes of no activity the meter will automatically shutdown.In real life sometimes after 5-10 minutes of no activity the meter will shutdown
Continuity mode
Fast response,no scratching
Capacitance
It has no internal residual capacitance
The maximum reading is 100 microF
Diode
Voltage output in diode mode is 1.555V
Thermocouple and temperature
The multimeter contain an internal temperature sensor for measuring the ambient
K-Type Thermocouple it's a crap,the banana plug remains stuck in input jack.You need to apply a big force to get out
At the beginning it was a huge temp difference between MS8239c and Brymen BM869s,the MS8239c show with 8 degrees more then Brymen.After this i cleaned up the PCB and temperature difference was reduced
Accuracy
Was tested against my favorite meter BRYMEN BM869S
For this i will add pictures
As follows
Capacitance
Temperature
Resistance
DC V
AC V
Hz
DC mA
DC A
AC A
Click here for pictures
