Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Mastech power supply fuse blows intermittently
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Mastech power supply fuse blows intermittently (Read 2567 times)
Vytautas
Regular Contributor
on:
March 13, 2013, 08:13:05 pm »
Hi, guys.
Could someone help me with my Mastech power supply problem? I got a power supply Mastech 3005-2, similar to this:
Mine has only one difference, - it does not have a separate constant 5V/3A output.
The schematic that I found is this:
http://img-fotki.yandex.ru/get/5701/dinamicvolt.61/0_48280_bd1a55c7_orig
The power supply works OK. I have an oscilloscope and have tested the outputs - there is no overshoot or undershoot upon powering on. But occasionally the fuse (4A) blows when powering on. What could be the problem? Is it an inherent design fault or something else? Could I fix/improve it somehow? Thank you.
Logged
SeanB
Super Contributor
Country:
Re: Mastech power supply fuse blows intermittently
Reply #1 on:
March 14, 2013, 07:13:58 pm »
If it is the mains fuse replace with a slow blow 3.15A one, which should cure this. Most likely it is the surge current at switch on doing this.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
