That Elma 5800 very much looks like the Extech MG302 and the Di-LOG DL9307 that I have reviewed on the element14 website.
Extech MG302 review
https://www.element14.com/community/groups/test-and-measurement/blog/2018/11/13/extech-mg302-reviewDi-LOG DL9307 review
https://www.element14.com/community/groups/test-and-measurement/blog/2019/02/13/di-log-dl9307-insulation-tester-reviewRS Pro also have a similar version without the wireless communication
RS Pro RS9985 Review
https://www.element14.com/community/groups/test-and-measurement/blog/2019/09/28/rs-pro-rs-9985-insulation-tester-reviewThese units are in actual fact from CEM, a Chinese manufacturer
http://www.cem-instruments.com/en/Product/indexThe actual meter is at
http://www.cem-instruments.com/en/Product/detail/id/910The quality of these meters is very much hit and miss. The MG302 was the best version in that respect, but I believe it was quite an old one. The Di-LOG and RS Pro units were not good in terms of quality.
The wireless communications did fail on me on the MG302, and despite talks with Extech support, the issue was never resolved.
The Di-LOG unit failed on me when I was accuracy testing at 1000V. Two of the varistors went open circuit. It also has an excessive short circuit current on the insulation test that exceeds the limit in the IEC standard. Di-LOG have never responded to this query, neither has CEM. I did manage to fix the varistors, but have never determined how to reduce the short-circuit current.
The RS Pro has worked throughout the tests, but on opening it up, the connection strip for the 10A terminal was not soldered correctly and fell out. There was also solder spatter around inside and evidence of rework. I have never contacted RS about the issues.
In some respects it is a shame, as the concept of the unit is quite clever and it would be a really useful device to me for my work.
I have a Brymen BM877 that I am starting to review, but am no where near ready to post anything about it yet.
Obviously you know what type of work you will be doing and your budget, so what you purchase is up to you as far as I am concerned. I will say though that an Insulation Multimeter is a compromise between the two instruments. It will never be as good as a multimeter for an electronics lab and never quite as good as an insulation tester would be for a rewind shop. But as a tool for a jobbing electrician, insulation multimeters are fantastic.
Kind regards
