I got the Alientek but with a small error, it doesn't want to start heating and it stops working.
The seller has already sent the replacement part.
I tested the Fnirsi with my Uni-t thermometer, type K and the small end, 1 cm from the end and without a nozzle.
At 300 celsius it ran up fast to 277 degrees when starting, then dropped back to 220 degrees. It also held with a +- 10 degree difference. At a fan setting of 10.
When I set the fan to 20, I didn't experience a significant change in the temperature, it went up to 225 on average and kept the +- 10 degree difference.
When set to 450 degrees with a 20 fan, it went up to 320 degrees, the difference was also +- 10 degrees.
When I turned the fan down to 10, the temperature went up to 360 degrees, but here the difference increased to +- 15 degrees.
It keeps the temperature well, if someone has a bigger difference than this, there is a high chance that there may be a bug in it.
When soldering PCBs, the temperatures are of course different, higher, just like with a larger surface area thermometer head!
I've soldered a few things with it and it works well.
It is louder than the Alientek, but I think it is tolerable.
The grid at the end is much thicker on the Fnrisi, meaning the holes are smaller. It is about half the size of the Alientek.
I think it can be used well with a nozzle larger than 6mm, but it does not pump enough air for the smaller one, I think it is worse to use with the smaller nozzle, at least compared to the yihua 8509.
This is my 4th usable Fnirsi product and only 9 have ended up in the trash. The ratio has improved.
