Author Topic: Ucurrent  (Read 1748 times)
Offline billgTopic starter
Ucurrent
« on: December 16, 2014, 05:27:42 am »
I was thinking of getting a u Current for testing both flame rectification (uA) and ionization current (nA).  My question is that since half of the cycle is going to be in flame rectification mode and the other half ionization, how will it react to over range in nA setting ?
Offline TriodeTiger
Re: Ucurrent
« Reply #1 on: December 16, 2014, 05:43:43 am »
If the battery voltage is increased to 5.5V (maximum) the range for nA will become ~0-2250nA, as the highest value (1mV/xyz) would be at 2.25V, because of the virtual ground (?) - so it can't go much over-range, but if it's below 2.2uA..
« Last Edit: December 16, 2014, 06:12:19 am by TriodeTiger »
"Yes, I have deliberately traded off robustness for the sake of having knobs." - Dave Jones.
Offline MLXXXp
Re: Ucurrent
« Reply #2 on: December 16, 2014, 06:50:17 pm »
If you go out of range, the output voltage will pin at close to + or - half the supply voltage.
If you're wondering about how safe it is to go over-range, here's a post with some (very conservative) calculations I did a while back:
https://www.eevblog.com/forum/crowd-funded-projects/current-gold-on-kickstarter/msg375819/#msg375819
If the uCurrent is always on, or you add some protection diodes for power off, the safe ranges increase:
https://www.eevblog.com/forum/crowd-funded-projects/current-gold-on-kickstarter/msg376311/#msg376311
The protection diodes, and modifications that I made to shift the virtual ground, which may be useful for your situation, are described here:
https://www.eevblog.com/forum/crowd-funded-projects/current-gold-on-kickstarter/msg448208/#msg448208
Re: Ucurrent
« Reply #3 on: December 16, 2014, 08:08:30 pm »
Thanks for the replies,  MLXXXp this is just the what I needed:)
