I see, thanks for the info! I thought it was some cool improved screen, but it's just a red backlight ...
Well, not exactly. Both the graticule markings and the red border are on the inside of the CRT glass. See photo.
The backlight bulbs are aimed into the bottom of the thick front glass and the light bounces off the red markings.
Many Tek scopes have a blue plastic filter placed over the CRT, and on many (all?) models the filter is removable. On a lot of used scopes the blue filter has been removed and lost, so what you're seeing in your first picture is likely the bare tube.
As edavid points out, there's also a clear filter available but I don't see those very often because they're not as good for beam contrast.
