Author Topic: Measure AC voltage and Frequency with DAQ970A  (Read 807 times)
Offline Jeroen3Topic starter
  • Embedded Engineer
    • jeroen3.nl
« on: November 11, 2021, 02:57:31 pm »
I'm currently experimenting with a DAQ970 + DAQM901A acquisition system, and I was wondering if it is possible to perform an AC voltage measurement and frequency measurement on the same input channel within a scan.
Anyone know how? Or do I have to wire up two channels?
Offline threephase
Re: Measure AC voltage and Frequency with DAQ970A
« Reply #1 on: November 11, 2021, 08:23:44 pm »
I believe you can only ave one measurement parameter per channel so you will have to wire up two channels with the same signal and use one for voltage and the other for the frequency.
Offline matches
« Reply #2 on: November 22, 2023, 10:20:17 am »
Include the same channel twice with a different configuration.
A bit late but maybe helpful for others having the same question.
