Author Topic: measure capacitance and resistance  (Read 2863 times)
Offline pini200Topic starter
« on: January 13, 2016, 02:31:49 pm »
hello
i search device that Automatically  measure capacitance and resistance
without Selector modes,and output data in RS232  .
Offline billfernandez
Re: measure capacitance and resistance
« Reply #1 on: January 14, 2016, 04:09:47 am »
« Reply #2 on: January 14, 2016, 07:59:52 am »
I am looking in the direction of Keysight U2741A
http://www.keysight.com/en/pd-1420686-pn-U2741A/usb-modular-digital-multimeter-5-digit?nid=-34319.787340&cc=IL&lc=eng
but he is  too expensive
i need one that can send command and get measurment (like R,C)
« Reply #3 on: January 14, 2016, 08:22:00 am »
No RS232 but you can trust these:
http://www.advancedevices.com/
Avid Rabid Hobbyist
« Reply #4 on: January 15, 2016, 09:17:39 am »
i need rs232 or usb connection
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #5 on: January 15, 2016, 10:19:28 am »
The DER DE 5000 LCR meter can readily measure what you have asked for when in the auto mode, however should you need to use the sort feature then you first need to select the particular mode either L, C or R and set the tolerances.
The unit can be ordered with the USB cable and obviously the software, I don't have the USB interface although I did download the software and others have looked at the serial decoding which I think from memory is done.
There are dozens of threads on both this and other LCR meters on the forum.
Offline MrSlack
« Reply #6 on: January 15, 2016, 11:27:24 am »
These are never cheap.
My first choice would be: http://www.tti-test.com/products-tti/text-pages/prec-lcr400.htm
Offline HighVoltage
« Reply #7 on: January 15, 2016, 11:38:09 am »
Take a look at the older Philips / Fluke PM6304 and PM6306 automatic LCR meters.
They have an optional RS232 or GPIB connector and you can easily grab the data, like R and C
They have reasonable prices from time to time on ebay.
« Reply #8 on: January 17, 2016, 06:17:31 am »
the device should be small with Dimensions like in the picture
and without LCD
Thank
« Last Edit: January 17, 2016, 06:20:02 am by pini200 »
