Before I forget, I would like to thank you all for all the information you share, I learned a lot.
Meanwhile, I got a nanoVNA. I am still waiting for a few cables and adapters so I couldnt test much things yet, but I am already impressed with what I saw.
I mainly understand the point or difference about calibration kits. If I also understand correct, more expensive ones gives their LC characteristics in a polynomial model/fit (c0, c1, c2..) and their delay, loss etc. values. I saw a relatively cheap one (I think it was Rigol), it was saying all these values as 0, so I think this means it is an ideal thing, but naturally it is not, so that will cause some errors, and that is the difference. So I guess high quality calibration kit means to be close to ideal or maybe more correctly to be more close to its individually measured model, so the VNA can remove most of the error.
I am interested in stuff up to ~1 Ghz at the moment, so much easier and cheaper regarding to calibration, connectors and cables I guess.
Good you mentioned about PCB design. The actual reason I started questioning about these is I am working on some simple (opamp based at the moment) stuff but I would like to go as high frequency as possible (up to Ghz). Just by prototyping, manhattan style etc., what is the reasonable freq. I can go ? For example, with a high bw opamp (1Ghz+) in a voltage follower configuration, what freq. I can reach in a prototype ?
There is something else I wonder. Most of the simple VNAs or SAs with VNA features, can do s11 and s21 measurements, hence, if I am correct, they are called one path VNAs. The "big" VNAs are I think always two path, so they also measure s22 and s12. I understand this eliminates the need to reverse the DUT for measurements, but is there another benefit of this ?
Another question. I guess a differential amp has three ports, not two. So it cannot be measured with a two port VNA. Is there an approx. way or a workaround to accomplish this with two ports ?
