Author Topic: Measuring tempurture of a light source with a IR thermometer  (Read 6715 times)
Online Fraser
Re: Measuring tempurture of a light source with a IR thermometer
« Reply #25 on: October 09, 2017, 04:40:53 pm »
The function of a Pyrometer is the same, correct.
However the term Pyrometer when searching on the Internet will bring back results for all manner of temperature measurement devices that are not a modern Thermopile based IR Thermometer. It's a little like searching for an "internal combustion engine" when all you are really only interested in is the Diesel engine !  ;D
Pyrometer is an over arching category of test equipment that merely details that it is a thermal radiation measurement device.
Fraser
« Last Edit: October 09, 2017, 04:42:48 pm by Fraser »
Offline videobruceTopic starter
« Reply #26 on: October 09, 2017, 04:51:41 pm »
Initially it appeared to be a different animal just adding to the confusion.  :(
Online Fraser
« Reply #27 on: October 09, 2017, 04:59:28 pm »
Indeed, there are many terms used. You can have 'contact pyrometers' as well !
I attach a range of Pyrometers for your interest  :)
As you can see, they come in many forms.
Fraser
« Last Edit: October 09, 2017, 05:01:36 pm by Fraser »
« Reply #28 on: October 09, 2017, 05:10:56 pm »
Scouring thru Amazon, I found many analog automotive gauges that came up using "Pyrometers" as the search entry.
Online Fraser
« Reply #29 on: October 09, 2017, 05:13:48 pm »
« Last Edit: October 09, 2017, 05:16:26 pm by Fraser »
