Author Topic: Metermaster 65601 ocilloscope repair  (Read 881 times)
Offline CaloTopic starter
« on: June 05, 2022, 02:26:44 pm »
My oscilloscope vertical axis dose not go above half of the screen, it only works right for a few second than it drops below middle of the screen any one had issues like that?
« Last Edit: June 05, 2022, 03:09:40 pm by Calo »
Offline Chris56000
Re: Metermaster 65601 ocilloscope repair
« Reply #1 on: June 05, 2022, 08:49:13 pm »
Hi!
The Metermaster 65601 Oscilloscope is a clone/rebadged version of the Aron BS–601 and an instruction manual with theory of operation notes, parts lists, adjustment notes, layout and circuit diagrams can be downloaded from k04BB!
http://www.ko4bb.com/manuals/77.101.201.133/Aron_BS-601_20_MHz_Oscilloscope_Operator_Manual.pdf
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
The following users thanked this post: Calo
« Reply #2 on: June 06, 2022, 02:24:12 am »
I turned pretty much every adjustment pot no change
https://youtube.com/shorts/W2Qd8UkSy7Q?feature=share
« Last Edit: June 06, 2022, 02:34:02 am by Calo »
Online Grandchuck
« Reply #3 on: June 06, 2022, 12:52:06 pm »
The manual on page 23- shows the vertical output circuit.  Check the supply voltages and then work backwards from Q17-Q20.
