I've just been scrolling through the open pull requests on github and there is actually someone working on fixing the Siglent SDS E-series driver, awesome!
@fredo_ if you have time, could you please kindly share a compiled version of the PR247 so that we can test the changes? I'm still not able to get the building process working
Hi @qubit,
Yes I'm aware of this PR and already proposed to merge it with mine on Sigrok Discord channel.
They are preparing a release and plan to integrate some PRs to it, Rigol and Siglent driver update PRs (245,246,247) are candidate for it: https://sigrok.org/wiki/Developers/Release_0.8.0
TBH I'm not spending more time on it until I'm sure this eventually make its way to upstream ; I moved to another project (ngscopeclient) for now.
I can try and guide you to have your build work thought, what platform are you using?
I am trying to build for Windows 11. I am using MSYS2/Mingw64 and the sigrok-native-msys2 script from sigrok-util
https://github.com/sigrokproject/sigrok-util/blob/master/cross-compile/msys2/sigrok-native-msys2. I've changed a few lines in this script.
I've changed the git repository for libusb to point to the official libsusb repo's master branch, the libsikrok repo to the siglent-sds branch of mike42's repository and the repository of pulseview to the Fix/71 branch as described in the pull request PR247
https://github.com/sigrokproject/libsigrok/pull/247.
I can build pulseview sucessfully and also run it from within a Ming64 terminal.
When running pulseview from MinGW64 I get a lot of python ModuleNotFoundErrors in the console output: No module named 'math', No module named 'binascii'. These are internal modules of python, so they shouldn't have to be installed. Is there maybe something wrong with the python installation?
When I try to run the pulseview.exe executable from within Windows I get error messages:
The procedure entry point _Z20qResourceFeatureZlibv count not be located in the dynamic link library, hinting at a problem with the Qt5 dlls. I guess that when running from within MinGW64, the PATH variable points to the correct locations of Qt5Core.dll and all required dlls.
When I run the command
ldd ./pulseview.exe
I can see that Qt5Core.dll will be loaded from /mingw64/bin/Qt5Core.dll, as well as a lot of other dlls that also will be loaded from /mingw64/bin/.
How can I compile Qt5 into the pulseview executable statically, so that running pulseview.exe from within Windows does work? Did you also run into such problems?
