Sorry if this is a bit of a newbie dumb question, but I have the following multi-meter - only about 1 month old
Just recently I noticed that the display is showing fluctuating result on the dc voltage settings, however it always reset to 0 when I touch the red and black probes which I understand is desireaable. however when I try to measure for example a 1.5v Aa battery the screen display 1 - as if out of range. I've tried the other ranges and get the same. The diode/continuity mode seems to work ok.
Any ideas - I tried the battery in another meter and seems ok.
