Author Topic: E36300 Series Programmable DC Power Supplies (E36311A, E36312A, E36313A)  (Read 43278 times)
Offline thanasisk
Re: E36300 Series Programmable DC Power Supplies (E36311A, E36312A, E36313A)
« Reply #250 on: March 27, 2020, 12:22:25 pm »
How is the web based control on the keysight?
Also did you find  the logging feature any useful ? Does it do any sort of averaging or is it instantaneous? Also what is the min time step/offset?
The following users thanked this post: Andrew
Offline capt bullshot
« Reply #251 on: March 27, 2020, 03:57:22 pm »
I did some "tricks" using the advanced features:
http://wunderkis.de/E36312A/index.html
Anyway, for regular use these features are too cumbersome (at least to me).
Can't tell anymore, guess you'll have to read the manual ;)
The following users thanked this post: Andrew, thanasisk
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #252 on: March 28, 2020, 09:00:36 pm »
I used Keysight's software only briefly, but it worked very well.
To me the interface of the power supply itself is quite good, so I didn't see the need to invest in the software.
The logging is very useful to me and I used to capture battery charge curves. I don't recall averaging being implemented in the supply. It can save all data in .csv format to a pendrive, so Excel or other spreadsheet software can manipulate data quite nicely.
The sample interval goes from 200ms to 60s and the supply nicely calculates the time duration depending on the sample interval, the different collection of logged information per channel (P, V, A) and the memory available.
Offline thanasisk
« Reply #253 on: March 29, 2020, 04:09:44 pm »
Nice tricks on emulating a load, but it indeed take too much work
Offline thanasisk
« Reply #254 on: March 29, 2020, 04:14:05 pm »
Thanks for the info . I guess measurements/log performed right on the instrument are more accurate (in time/timestamps) than reading back through lan/pyvisa etc. since they avoid the command overhead and jitter. Although 200ms is not too fast. Have you found this restrictive?
Offline rsjsouza
  • Eternally curious
« Reply #255 on: March 29, 2020, 10:35:21 pm »
It is restrictive if I want to log fast current transients, but for that I have an oscilloscope.
I simply live with the fact this is a pretty good power supply with a built-in 5Hz DSO - plenty for what I use.
The following users thanked this post: thanasisk
Offline thanasisk
Hi, is the (transformer?) hum normal? It appears as soon as the device gets plugged in.
Offline nctnico
My unit also likes to hum.
Offline rsjsouza
  • Eternally curious
It is certainly part of the advanced pre-heating circuit that keeps the backlight always on |O
(My only real pet peeve with this otherwise marvelous bit of kit)
Online TheSteve
  • Living the Dream
Mine is always silent except if I run a heat gun on the same circuit. I get the same buzz/hum on some other HPAK supplies as well with the heat gun.
VE7FM
Offline Fred27
    • Fred's blog
It doesn't just hum when plugged in, it draws about 10W on standby. It really does need a proper physical power switch.
« Last Edit: August 23, 2020, 06:47:54 pm by Fred27 »
