Author Topic: Mettler TM15 RDT PT100 mecanical temperature display 1970 test teardown  (Read 1056 times)
Offline oz2cpuTopic starter
    • webx.dk private hobby and diy stuff
this one i just have to share :-)
my latest
Mettler TM15 RDT PT100 temperature display 1970 test teardown
This is one of them WOW how cool type of display readout tech :-)
mecanical counter, gears, stepper motor, feedback potentiometers,
bridge, PT100 sensor, AC drive and compare with ref potentiometer,
to figure out if motor needs to go forward or reverse, amazingly nice construction, and it really works.
video link
https://youtu.be/DJZji0WJ-Ho
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
The following users thanked this post: Vgkid, Kean, MK14, BILLPOD
Online MK14
Re: Mettler TM15 RDT PT100 mecanical temperature display 1970 test teardown
« Reply #1 on: November 02, 2023, 11:36:42 am »
Nice video, and very interesting piece of equipment.
I'm wondering, what the display shows if the temperature goes negative?
Also, as it seems to show ' [ o ] C', can it be switched to a Fahrenheit scale 'F'?
Edit: Putting some table salt, onto the ice (ideally with little or no, extra water, as it dilutes the salt action), should create temperatures below zero Centigrade.
« Last Edit: November 02, 2023, 12:27:13 pm by MK14 »
Offline TomKatt
« Reply #2 on: November 02, 2023, 12:19:07 pm »
Great video!  Subscribed!
They had several numeric display technologies in 1970 (planar, nixie, numitron etc)...  I wonder why they went with a mechanical display ?
Several Species of Small Furry Animals Gathered Together in a Cave and Grooving with a PICt
Online MK14
« Reply #3 on: November 02, 2023, 12:30:39 pm »
I think it is because its circuit action, is basically analogue (comparison, between the measured temperature, and the potentiometer, which moves along with the mechanical counters, if I have following things correctly), so it doesn't need the digital circuitry for the other display types, which would have been very expensive, at that time (or even non-existent, depending on when this design was first used).
I.e. If this technology was old enough (when it first came out), it could pre-date, integrated circuit counters and stuff.
« Last Edit: November 02, 2023, 12:33:37 pm by MK14 »
« Reply #4 on: November 02, 2023, 12:53:49 pm »
I think it is due to the compare potentiometer is insanely accurate and linear,
converting potentiometer position to a type of readout that is non mechanic
would add all sorts of not so accurate details
I also like the fact that this unit display the last known value, when power is missing
The following users thanked this post: TomKatt
Offline TimFox
« Reply #5 on: November 02, 2023, 01:52:23 pm »
The technique is similar to analog chart recorders, where the pen position is encoded by a potentiometer, whose voltage output is compared to the analog input.
I remember old 40-turn "servo" helical potentiometers that had linearity on the order of 0.01%.
The following users thanked this post: MK14, oz2cpu
Online MK14
« Reply #6 on: November 02, 2023, 02:04:21 pm »
Wow!
I'm surprised the potentiometers, don't keep wearing out, in such applications.
I suppose such instruments were used a lot, before digital logic became common place.
« Reply #7 on: November 02, 2023, 05:04:43 pm »
exactly, those potentiometers is mostlikely what define the cost of this unit !
BOURNS the largest blue model
Online MK14
« Reply #8 on: November 02, 2023, 05:39:56 pm »
The following free PDF handbook, seems to nicely fill in the details.  For anyone who wants to know more about precision (and other) potentiometers, like I did.
https://www.bourns.com/docs/technical-documents/technical-library/corporate/OnlinePotentiometerHandbook.pdf
They seem to have helped fill in the gap, for creating powerful (e.g. control and measurement) functionality, until cheaper electronics (especially integrated circuits), could fill in the void, in later years.
Edit: Also for trimmers:   https://www.bourns.com/docs/technical-documents/technical-library/trimmers/technical-articles/trmrpmr.pdf
« Last Edit: November 02, 2023, 05:43:57 pm by MK14 »
Offline Vgkid
« Reply #9 on: November 02, 2023, 09:05:33 pm »
Thanks for the teardown, I have never seen a thermometer with a mechanical digital displsy.
