Author Topic: MHS-5200A New Software  (Read 10111 times)
Offline danadakTopic starter
« on: April 30, 2016, 04:58:18 pm »
I loaded this new version (attached), connected gen, and tried to do an arbitrary waveform.
Loaded it on "Arbitrary" tab, then wrote to arb00 mem location.
https://www.dropbox.com/s/cdlsuv2w5rkss6g/MHS-5200A_en5.0.rar?dl=0
It shows up on "Control Panel" tab when I select arb00 as wavefom,
but does not output out of the generator.
I need a drink........
Also sweep mode do. And no sweep trigger out of TTL outputs on gen to synch the display
on scope to the sweep. Although I think one could use 2'ond channel to create the trigger
as both channels operate off same time base.
Regards, Dana.
« Last Edit: April 30, 2016, 06:19:09 pm by danadak »
Offline r07
Re: MHS-5200A New Software
« Reply #1 on: December 17, 2016, 10:02:51 pm »
I recently purchased an MHS-5200A and followed the instructions for installing the software.  the software version is 5.01.  am not able to connect the software to the device.  tried your software on Dropbox, which is an earlier version, but no success.  have tried this on two PCs - one running W7 64bit and the other Vista.  any comments or suggestions welcomed!
